My Polo Coupe S - Project Part deux
Today made the repair plate for the rear arch
Mike cleaned out the rear chassis rail back to clean metal
which got bigger
and bigger
It seems the water was just sitting in this area. But even though a lot was cut out it actually makes it easier to repair :)
  • Replies 1.3k
  • Views 297.2k
  • mark_crox
    mark_crox
    I don't know what you mean......
  • Right a bit of an update is over due me thinks. Last August I noticed some rust under the sill trims.. Luckily is was only light surface stuff where there was a thin covering of paint. So after cryin
  • Cheers Simon. I does go well and the more miles I put on the engine the quicker it seems to get :) Not really done much apart from completing the 2000 mile european road trip. Hit Polo Treffen in Ho
Wow that is some work being undertaken there. Will be worth it in the end :-)
Makes me worried about my mk2 now :-( but this proves that a lot of dedication can fix most things
Keep the updates coming
I wonder if one or two more small drainage holes could rectify this? Theres a few dotted about from factory, but they either haven't been working as they should or have maybe become blocked with road grime?
New metal will be going in and once the whole car is done all the cavities will be wax oiled, this will stop any of this rust coming back. It seems the water got in and soaked down into the the corners of the rear chassis box section. If I had done this a few years ago it wouldn't have been this bad. And to do a whole car is rather cheap.
just been through the whole thread mate...what a journey!!
Inspires me to pick up a mk2/3 and have a little play
Cheers :)
Another Saturday at the body shop!
..and the 2 polos finally meet! :-D
Mike has welded all the repair patches in place for the rear chassis rail
Mike Cut and Welded in repair patches for the inner arch
And also cut out the Mk1 rear arch to use as the repair panel for the Mk2 inner arch
Coming on nicely Mark :-). Be nice to have this and the MRS meet at a show after all they've been through :lol:.
Cheers Karl..
Yeah it would be nice.. actually getting to the point where I could drive the thing would be nice! :lol:
Massive respect for this. Anyone else would have just re-shelled it.
It worries me that from the outside the shell looked pretty dam clean, then after inspection its a totally different story.
Think I'm gonna order some underseal :lol:
Good work mark!
You are probabbly wright about the re-shell but it just wouldn't have been the same car!
Yeah that's the worrying thing there was just a small bit of rust by the filler flap and the rest of the car was almost mint. But its only when you start pealing stuff back that you finally see the whole picture!
Test fitted the new inner mk1 arch
Seems that it will do the job fine :)
Had a little trip to london this afternoon to pick these up..
they will eventually look like this:
or
Also I've been accessorising with a retro cooler :lol:
Any updates Mark? Its been a good few weeks.
I haven't seen the car for 2 weeks :(
Heading down tomorrow to work on her, should be fabricating the inner fuel hole area. The rear quarter should go back in in the next couple of weeks hopefully :)
I vote gold for the wheels! :-D
I'm thinking bronze... :)
I say bronzey, coppery could would suit the centres so nicely. Don't do black, you lose all the detail in the lattice of the wheels.
Saw this caddy and maybe not so red but metallic centres are a must: caddy. Scroll down for the better pics.
Get this finished i want to see the finished thing. I don't care how busy you are :-p
Edited by demolover
Yeah I want something interesting as the rest of the car will look standard so the wheel colour are the only think I can change to make it stand out a bit :)
I was thinking that about black.. Gold is good but everyone has it (perhaps they do cause it looks good)
I'm trying to get it finished... I'm going to see If I/they can put a few extra hours on it during the week just to get the body work done and into primer..
A lot of people do gold but also a lot of people do black and i just think black on lattice wheels makes them lose a bit of the detail and then they just look like any 13" with a polished dish.
To say how fresh the car will be i think metalic centres are a must. The reason i like the coppery/bronzey look is that i think it does well with the red/orange light clusters. Sure you will come up with something good but i say make the most of those sexy wheels you have.
Really can't waiti to see this finished. I bet you are itching to drive it again.
Hell yes.. this weather really isn't helping as its perfect for it.. and I really want to be taking weekends away with/showing the car.
Looking goood.
I hope it's staying the standard colour!?
Looking goood.
Cheers..
Yep externally its going to be totally standard apart from the wheels.
how about a black chrome centre with diamond cut rim?
Quite a productive day at the shop..
this is the mk1 outer arch test fitted
and you can also see the metal work that Mike has put together to fix the fuel filler area
I marked up the quarter panel for cutting...
and then fitted it to check the inner arch
What we found was that even though the arch was similar its not quite right. So Mike is going to make up his own inner arch edge to match the mk2 outer panel :)
Looking good, bet you can't wait to get it back now!
I look forward to the day when I look out my window and its on my drive.. :)
Getting to the last bits of the driver rear quarter.... thank god!!!
I cut out all the crap and rust from the fuel filler hole and the breather pipe hole
Mike welded in the brand new fabricated plate. This was made just out of 2 pieces
He stayed on after lunch to get bits done and I got a picture from him... all welded, sealed and painted
Yipppppy! :)
