My Polo Coupe S - Project Part deux
The front wheels..
they do sit flush and with the plastic arches on should be fine.. Even more so when I can remove the wheel spacers
Spent the day working on the brake master cylinder setup
Cut off the old bolts on a spare pedal box and welded in new 90mm M8 bolts
mocked up
with a spacer
and test fitted
perfect.. :)
Also..
  • Replies 1.3k
  • Views 297.2k
  • mark_crox
    mark_crox
    I don't know what you mean......
  • Right a bit of an update is over due me thinks. Last August I noticed some rust under the sill trims.. Luckily is was only light surface stuff where there was a thin covering of paint. So after cryin
  • Cheers Simon. I does go well and the more miles I put on the engine the quicker it seems to get :) Not really done much apart from completing the 2000 mile european road trip. Hit Polo Treffen in Ho
Man tha is such a neater way of doing things. I have a mind to re-do mine the same! Still, spunked too much on it to go back now!
Your going to need a hell of a lot of those pacers! How close is the reservoir to the bulkhead now?
Yeah I was really pleased, and I don't have to cut the bar on the pedal
its about 5-8mm from the bulk head.
What I did find is that the 6n reservoir didnt fit the G60/ 16v master cylinder with the standard rubber bungs in. Luckily I bought a 6n master cylinder and reservoir from eBay so I used the bungs from that and it fitted fine.
i can see why your having a problem with the reservoir now lol it didnt click before as i was wondering why you were having so much trouble and mine was mega straight forward its because i have no firewall bulkhead bit i removed mine for a smooth bay so its obviously not in the way lol
looking good so far Mark i need to go update my thread soon done quite a bit
I've cut my rod now, although I'll take the pedal box from the coupe, and maybe move to a set up like this. Just sold my golf reservoir though. Grrr!
these turned up today..
.. that is all :)
What, new feet?
yes... to go with the harnesses... :)
Did you get the spacer yet? I got the templates the other day, thanks for that
Those wheels sit perfectly mate! You wont have any trouble with those,
Car is looking better and better!
Tell me more about that tax disc?
Yes.. it turned up today! :) Cheers.. I hope the templates are ok... its quite hard to draw round a mat!! :)
Cheers.. its finally nearly there.. was trying to fit the radio and bluetooth on Sunday. So the fact that I'm messing with that kinda stuff means I'm not far off. MOT should be booked in next weekend :)
http://www.britishtaxdiscs.co.uk/order-tax-disc.php :)
awesome stuff!! have you spaced the rear wheels out to match? or are they staying put?? cant wait to have a look over it!
Edited by erixtar1992
the rears have a 3mm spacer also, clear the rear callipers
oh right nah i meant have you spaced them so they sit inline with the front wheels arch wise
Oh no... I haven't. The rears sit fine I would like the fronts to fit where the rears do. As I think if I push it hard the fronts will scrub :(
hmm yeah i see your point, unless your running pretty stiff suspension then flush wheels will rub as I've found out :lol:
Really looking forward to seeing this at polo-show, there's gonna be so many epic cars!
I totally agree... there are so many really good builds going on it should be great!! :)
got my spacer back :)
fits perfectly
needed to drain the radiator so I could get the exhaust manifold off to wrap it.. so I took the car out side which lead to me giving it a wash down :)
the 2 'kids'!
The wife wrapping the exhaust
letting it dry and we will trim all the bits tomorrow!
It just gets better and better!
:-D cheers!! :)
Got the brake lines fitted..
needer to re make the drivers front as it was about an inch too short.
The bite point of the brakes is now perfect...
List of things to do
Top work! :-) :thumbsup:
Jesus, how is your list shorter than mine!
This looks very nice, looking forward to seeing this. Such a complete build
