My Polo Coupe S - Project Part deux
Jesus, how is your list shorter than mine!
This looks very nice, looking forward to seeing this. Such a complete build
because your still faffing with your rear brakes, just try them! u have a 50% chance of them being on the right way round :lol:
  • Replies 1.3k
  • Views 297.2k
  • mark_crox
    mark_crox
    I don't know what you mean......
  • Right a bit of an update is over due me thinks. Last August I noticed some rust under the sill trims.. Luckily is was only light surface stuff where there was a thin covering of paint. So after cryin
  • Cheers Simon. I does go well and the more miles I put on the engine the quicker it seems to get :) Not really done much apart from completing the 2000 mile european road trip. Hit Polo Treffen in Ho
mark, i am so glad not to see poorly bent copper lines everywhere! love this!
yeah I hid all those behind the engine!! :-D
oh and..
IT LIVESSSSS!
sounds great!
She drives!!
Went though every nut and bolt and torqued them all up, did some bits at bobs and took her for a spin round the car park.. its epic. Brakes are interesting though!! I think I'm going to have to put a regulator on the rear wheels as under hard braking they lock up way before the fronts do. It may just take a while for the fronts to bed in as they are DS2500 pads and they need more bedding in than the piece of crap ones I have on the rear. So I'll see how it goes.
i cant imagine how good youre feeling right now! well done indeed mate!
Cheers!! :)
too be honest I'm just feeling so tired!!! For the last 3 weeks I've just been doing 7 day weeks!. The 5 work days doing a 4 hr commute each day and then and a 2 hour drive each day to the body shop on the weekends/bank holidays. I need a break.
Will be over the moon if it passes the MoT and I just want to get it out and use it and then to a show!
Yeah I'm working 7 day weeks at the minute mate. Just pure work though, takes it out of you!
It's so worth it though
yeah.. it will be once I get it back on the road :)
Had the day off and just popped over to see it and it was sat outside the shop in the sun... it was nice! Looking forward to stanford hall :)
door cards in
those door cards are lovely! are they retrimmed?
Cheers... yes they are.
aw maynnnnn! haha. atleast you can say there unique! awesome!
Those door cards are awesome dude! love this car!
you Mr Croxford have a car that is the definition of pimp.
Absolutely fucking love it!!!
You've done awesome with this. Have you got any other pictures of your door pods? I'll be doing the same. How did you get over the fact that the door cards are the same both sides, i.e long pocket/short pocket on the front (L/R)?
Four. Fucking. Stars.
What's wrong with people?
Well done, Mark. Pimping interior, still looks OEM as well. Lovely, looking forward to seeing this either at the Polo show or BVF :thumbsup:
Jealousy i can only imagine
Absolutely love this car dude :drool: nice to see someone go full out on a mk2 ;)
Thank you guys.... :-D
I'm really liking the interior... well the whole car actually. Its one of those cars that I think people won't notice too much as its hopefully done in a style that might make people think it came out the factory like that. So its only when you start to look or you know early polo's inside out that you notice these things.
As for the door pods I just put a separator in there. I'll try to get a picture tonight for you.. :)
It has 12 months MoT on the car now!! Di a couple hundred miles in it the weekend. Some might have seen it at DivaDubs :)
Things I need to do
- New exhaust, Getting a Longlife fitted on the 25th.. which should mean it will no longer foul the body
- Add a throttle return spring to the accelerator pedal and adjust the cable so its less sensitive
- I think I need to put a brake regulator on the back or run one line to the back and split it out at the rear axle. Would this decrease the braking pressure to the rear. As its very easy to lock up the rears. Also I might go down to a Smaller master cylinder as you really have to stand on the brakes to get it to stop...
- Clutch pedal needs adjusting as the bite point is almost the floor.
- Need to work out why I'm not getting power to the radio or cig socket. Its not a fuse! :) Might have to get the dash out.. :(
- Fit speaker pods.
- fit the lower dash parts
- PanelnPaint (the bodyshop) are doing some final bits and bobs for me including fitting the Arch trims.
Not all this will be done for Stanford but the main bits will be! :)
Waiting for its test
and at DivaDubs
oh has anyone got some mk2 interior wing mirror covers with all the pins still attached?
Speaker pods..
I wonder what ride height ARB blocks are actually made for, is that a 40mm kit? Wheels look too far forward?
yeah they do don't they... I've also has to space the blocks down by about 5mm to clear the exhaust manifold..
I really need a stage 3 subframe but will need it custom making to clear the manifold...
I have drivers side one which i took off very carefully.as i.remembered u asking for one haha. Ill bring it to poloshow x
