My Polo Coupe S - Project Part deux
Cool stuff mate,
Regarding bodies, just for hooning around carbs are fine, even reasonably good on fuel compared to the likes of fixed Venturi carbs,
Read a massive build on a ford forum, bloke had mappable ignition and carbs, 173hp, spent nearly £2000 on a decent ITB setup, got 176hp, and to be honest the whole range wasn't a great deal better, he said driving it was barely noticeable, I suppose you get the adaptability if was a daily or something though, and more accurate fuelling and that, but IMO carbs will work well enough to rule out spending however much more money.
  • Replies 1.3k
  • Views 297.2k
  • mark_crox
    mark_crox
    I don't know what you mean......
  • Right a bit of an update is over due me thinks. Last August I noticed some rust under the sill trims.. Luckily is was only light surface stuff where there was a thin covering of paint. So after cryin
  • Cheers Simon. I does go well and the more miles I put on the engine the quicker it seems to get :) Not really done much apart from completing the 2000 mile european road trip. Hit Polo Treffen in Ho
Cool stuff mate,
cheers.. :)
Yeah I totally agree. Its more of a would be nice to... rather than it would be money well spent. Doesn't stop the itch for me to give it a go though. :-D
Be interested to see how you get on with the mappable ignition stuff... :)
Exactly - dont get me wrong they're more than ideal in every way, and obviously can be done a lot cheaper using bike bodies and a home brew mani and that, but you can get the fuelling pretty good on carbs - was good enough for bikes for years and years, I'd imagine the injection stuff on them now is partly to do with emissions control, but who knows.
Will be interested to follow this - just going to swap your AFH bottom for the ARC are you? No other engine work? Suppose you won't be going to Southam again for setup this time since the move?
I'll probably do a bit of a review of the mappable stuff when it's sorted, just need to work out how I'm going to set it up, whether to do myself on the road, or do some on road then verify on a rolling road, or just get a RR to do it all.
As technically ill have 88 boxes to fill with values iirc! Which maybe very time consuming and £££ at a RR
Yep.. just swapping the bottom ends over but doing the drilling for the head bolts and the like.
I might still head down to Southam still as they did a top notch job last time and I don't know anyone local up in derby who I trust to do the job.
That would be interesting to see :)
Same route ill be taking I think, drilling the block and relay roller to retain the oil squirters, will see how guy gets on with his.
Southam were impressed with your AFH, was chatting to them about it, good bunch of guys
Yeah they are good.. love their yard with loads of Mini's lying arround.
Split the engine today
Got it up on the stand
Belt cover off
Belt off
rocker cover off
Head off
all looks ok I think :)
hope you have more luck with your ARC hybrid than me mate!
Hey Mark, all this is looking fantastic. Really taking it up another notch that I didnt know was there.
Hope to see the progress at a show this year.
JC
Fingers crossed!!
JC
Cheers!! :)
Hope to get this done for March... maybe!! :)
pushrods.. nice.. got to make sure they are all straight! direct injection is also a big plus!
No pushrods Joe, just hydraulically tensioned roller rockers. Has over head cams which are in the cam cover (which is then a cam carrier on that engine).
Also has VVT, though Mark Isn't using that head. I am, just without the VVT and with the same carbs Mark's using.
Carbd 1.6 AFH is an excellent engine Mark, and it'll look as good as it works.
I remember when you put the GT engine in - did you think then you'd be getting it to this standard..?!
Nice! I haven't seen a setup like that before! When i saw rockers i assumed pushrods right away! Living and learning! Thank you for the great info!
^^That's because you Americans are 30 years behind engineering wise, still struggling for 20bhp from an 8 liter engine :wink::lol:
Do you have like, a money tree or something? :D
Seriously though, very good read, very good build. Kudos to you pal.
I'm doing something similar (AFK lupo sport engine Eaton charged...)
Cant wait to see more
Edited by dmacz220
Hahah... not quite!
cheers.
Well it will be a couple of months before I get the engine in there plus there is some other bits and bobs I want doing. but It will get there :)
I've sent the relay roller off to be drilled out... except they couldn't do it, nothing would touch it. This has been reported by by a few people where as others have said they had no problem! So mine will be undergoing a process called Wire Erosion... which I had never heard of before!
Also been building up the speaker pods
Can't wait to get these in! I do need to look for a new headunit though. After one with a rear USB and bluetooth :)
mmm .. Gonna start building mine up soon, simular way to u did yours ..
how much and what spec on the focals mate ?
Mezzin!
I fuckin love this car man <3
i reconise that number plate.... was that ever registered in clacton on sea?
Umm I'm not sure of the speck they are Focal 130CA 's I think.
And I think I paid about 70-80 for them... but really don't quote me on that!
Mezzin!
Tar! :)
Nope its lived all its life up in the Midlands, well Kidderminster, Loughborough, Norwich, 3 weeks in Plymouth, Stourbridge, Leamington, Kenilworth and now Derby :)
Dropped the ARC bottom end off today and also picked my relay roller
amazing how precise and intricate the cut is! :)
Brand new Alternator for £14 :-D
Bargain that!
Build is looking good, hopefully you get a nice running 1.6 AFH!
Ebay i take it mark?
Looking forward to seeing this thing!
Cheers...
yep an eBay special! :)
