My Polo Coupe S - Project Part deux
What did you do with sills inside when you welded them up? I've got a fair bit of panelwork to do on mine, and am worried about treating behind the repair, i.e will they rust behind the weld and what did you do about it?
  • Replies 1.3k
  • Views 297.2k
  • mark_crox
    mark_crox
    I don't know what you mean......
  • Right a bit of an update is over due me thinks. Last August I noticed some rust under the sill trims.. Luckily is was only light surface stuff where there was a thin covering of paint. So after cryin
  • Cheers Simon. I does go well and the more miles I put on the engine the quicker it seems to get :) Not really done much apart from completing the 2000 mile european road trip. Hit Polo Treffen in Ho
I put loads of weld through primer on, which keeps it protected. And then make sure everywhere had a good coating of cavity wax.
How did you apply the cavity wax to the inside of the sills?
On the sills them selves there are drain holes which can be used. So with that and full coating of primer I hope it will be ok :)
Few small updates.
Fittted the new starter
also had the block drilled out for the m11 bolts, bores checked and the blocked cleaned up. Also its had a the blocked face slightly skimmed just to clean it up
Happy days mate :)
Sexxyyy!
Oh forgot that the dowls come out :/
Should of got mine skimmed abit tbf.
Owell :)
cheers... :)
need to decide on colour. think I'm going with standard satin black.
Also decided to use the 8P box from the original engine... I think!
just went through every page of this thread and wow this is one of the best mk2's I've seen, this is inspiration :-D
Well the pump is in and it fits like a glove :)
Hi mark :)
Blast from the past here.
i have a late mk2 polo that I'm converting to a gt at the moment for the polo show.
i need to know if i can use the same tank and what not.
do i just have to replace normal fuel lines and mec pump with the gt lines and an exturnal fuel pump?
will i need a new whatever that is called in the pick above going in to the tank?
cheers
Alan
Ps: your polo = lush :D
Cheers... :-D
Hi mark :)
cheers
Alan
Cheers! :-D
In a late Mk2 you should be ok to use the same tank. I did.
Yes you will need this, its call a fuel lift pump/fuel sender(for petrol gauge). On a mk2 the fuel is drawn from an outlet at the bottom of the tank (there is an inlet to for the fuel return). So you need to block or loop together these old inlets and outlets and then fit the lift pump from a mk2f and run the fuel pipes up to the top of the tank.
Yes replace the Normal lines with the GT ones and all the gt fuel pump stuff and fit the fuel pump wiring loom from the GT so you can get power to the 2 pumps.
Thanks mark :) your a legend for that info.
There was a bit of a fuzz in my head about what to do and how it works but now its all clear :D
cheers
cheers
No Probs..
Remember when I was first thinking about doing it, it didn't make sense but that soon goes.
some pictures for everyone.
fitted the door pods
going to create a leather wiring sleeve to hold the wiring in.
and just some from the pod
Managed to run a 16.21 (all of them where low 16's) which I didn't think was too bad (racing excuses) with a strong headwind, and boot full of stuff.
Hahahahahaha and as soon as I said it was windy in the morn you moaned at me for having excuses ready ;)
That last pic is sick!
Where did you think I got it from! :-D
what I did find interesting was the run that I thought would be my slowest was my quickest. Quite a bit of wheel spin off the line and loads of wheel spin when I put it into 2nd.
Would di it again just to get into the 15's. Will remove the contents of my boot and bowls first though! Plus put the rear seats down flat for extra weight saving!
Yeah it's so weird. You'll feel as though you've done a rubbish run and it's quickest haha.
Yeah surprised at your times, I know mk2's are lighter but I guess you had full interior etc, Jamie ran 15.7 in his carb'd AFH in a mk3 but had no interior like.
I might be going back to an RWYB soon, will let you know how much we can take off for wind haha
This felt nice on track, pretty well balanced :)
my fuel pump is attatched underneath my carbs lol shame the 1st one is shagged. 2nd looks like a biggun
-_-
She survived Cadwell Park! :)
No issues what ever apart from a dodgy fuse!
Just given her a quick clean for Diva Dubs
might have some new wheels in the pipe line so if all goes well the BMW BBS Mahle's might be up for Sale :(
I was about to say where are the Mahles?!
I did take them off for winter and never got around to putting them back on.. :)
Show pictures from yesterday
Picture update time!
Headed out to the Breakfast Club at Shelsley Walsh. Its a great little meet with loads of cool cars.. but I forgot to take pictures. Apart from one with the 3 cars together.
I've been on the fence for a while reagdding some new wheels... I thne saw these! :) Compromotive TH 14x6
AC41DACE-DA84-4DE6-9D2A-086440793A12-337
I've always liked them and I think they would really suit the car!
Down side is that they didn't come with center caps
But they look grand!
So I begin to fudge some caps together.. when I wonderd..
..yes that is a cap to a spray can!
so after a trip to halfords..
with added reinforcement so it won't loose its shape
So then off to Polo Show.. and a trip on the rollers
made 129bhp and 116 lbs ft of torque at the fly. I think they were reading high a bit as it was a baking hot day.
changed the spacers for the show and shine
and then it got dark
In the show and shine..
thanks to vDubLeics for the picture
Finally had to take some pictures for the Insurance so if all these pictures are not enough here are some more! :)
that's all folks!
New wheels suit it well. Looks lovely
