My Polo Coupe S - Project Part deux
The front grill badge is amazing!
You gonna rock that rear one, or is it just for keeps sake?
  • Replies 1.3k
  • Views 297.2k
  • mark_crox
    mark_crox
    I don't know what you mean......
  • Right a bit of an update is over due me thinks. Last August I noticed some rust under the sill trims.. Luckily is was only light surface stuff where there was a thin covering of paint. So after cryin
  • Cheers Simon. I does go well and the more miles I put on the engine the quicker it seems to get :) Not really done much apart from completing the 2000 mile european road trip. Hit Polo Treffen in Ho
It is just a keep sake :)
A few updates..
Headed out to Stanford Hall.. and Huyi met another family member
Started to mock up the brakes and suspension as well.
The type of shoulder bolts you need to fit the Vauxhall calipers
The pad carrier fouled the strut a bit which you can see circled
So just needed to tickle them a bit
Much better
Carriers on
Caliper on
All built up together with some new bump stops mounts and hubs
now to break them all back down and get them blasted.. :)
just gets better and better! love the fact this looks ace and gets used on track.
Mark, is the vauxhall converson with a 22m mster cylinder and that spacer you had made?
I have tried my Vauxhall conversion twice but cant get a biting point despite spending whats probbaly adds up to about 48 hours of real time bleeding an I think its because of the required additional volume.
When i put the VW11's back on i get a great biting point bake pedal immediately.
This is with goodridge hoses.
Ill follow here to see how the conversion goes.
JC
Cheers... She certainly does get used, I would feel rather bad if she didn't! :-D
JC
Yes I've got the 22mm cylinder and the spacer which is needed for the rear disk conversion I'm running. I've also got the smallest piston sized front Vauxhall calipers that I could find which i think is 52mm. So I'm hoping while it may make for a longer pedal it won't be too bad.
More stuff got delivered the weekend :)
will you be going retro rides gathering this year? if I can get my manifold sorted I will be, be nice to have a nose around another AFH install ;)
My girling 54's don't have a too long a pedal, neither do the vauxhall ones I run either. At least I haven't noticed a huge difference. Kudos for the road trip too. Something I still really want to do myself.
Certainly am :) Really enjoy the show...
Ahh thats really good to know! :)
Huyi looks great in this months retro cars.
Congrats on the magazine feature!
JC
Cheers!! :-D
Will be heading out first thing to try and find a copy! :)
Found a copy! :)
It's a really awesome writeup and great pictures.. I'm really chuffed! :-D
Been buying stuff for the front brake and H&R suspension setup as well as trying to refurbish some struts :)
also picked this up to have a go at putting in my own bearings.
Been looking at brake pads and I really want some DS2500's as thats what I'm currently running ad I really rate them. However I can only find them for the Turbo. Not knowing if they are the same and not wanting to spend £130 on pads that don't fit I thought I would find the cheapest set I could to try them out.#
£14 from Euro Car Parts :)
No they don't fit.
So I have the option of picking some other pads or stick with the current 239mm VWII setup... going to have a think!
MOT tomorrow!! eeeeekkk!
Thank you :)
Yeah saw the DS3000's but they need to get some heat in them for them to work so not to great for road use.
Yeah... bit of a rash decision but the right one for me I think. I have 2 sets of 13's, the standard hocks and a set of BBS Mahles that I really would like to keep and fit on the car everynow and then. Also 14 inch tyres are harder to come by in the size I need and track tyres are a no no. So it makes sense to stick with the VWII's :)
the car is being recognised at last! congrats on the mag feature, is it still available to buy?
Cheers.. yes, it only came out Friday :)
Ill have to get an issue, I'll see if my garage has it en route to work, will make an interesting read!
Been buying some bits and bobs.
First packaged turned up today. 7 row 235mm oil cooler with thermostatic sandwich plate.
Also this is one of the photos not used in RetroCars
Very good read mate, should be working though and got the boys interested in your polo now
haha awesome..
go and do some work! :-D
Got some new bits and bobs today.
New alternator. Mine has stated to make a racket
going to spend some time and try and work out if there is any way to fit the Mk2/2f crankshaft pulley rather than the 6 rib AVY one. As it really would free up a lot of space near the chassis leg.
Also .... :)
Aftermarket vs VW original :)
Were did you get the oil cooler from and how much? I need one for the turbo :) I saw Eric French fitted a v pulley to his 16v as he also had a trigger wheel for his nodiz on thier looked cool, might be worth having a look, congrats on the mag feature 👍
I got it all from JJC race and rally.
Thanks for the info!! :-D
and thank you!
Finally finished refurbishing the struts.
Used the after market brake disc shields and painted them up as they seemed to be thicker and more study. :)
I've been trying to find the mag but seems impossible around my way to get :(
Can you not buy the dust covers from VW still ? I bought some a couple of years back they came black but are still in the wrapping at home.
