My Polo Coupe S - Project Part deux
Is this round the right way?
Well I think so.. They haynes book of lies says that the bend in the front section of the bar must face upwards. which it does. But the bar is touching the Down pipe and it is also touching the gear box. So is the book lying to me?? :)
  • Replies 1.3k
  • Views 297.2k
  • mark_crox
    mark_crox
    I don't know what you mean......
  • Right a bit of an update is over due me thinks. Last August I noticed some rust under the sill trims.. Luckily is was only light surface stuff where there was a thin covering of paint. So after cryin
  • Cheers Simon. I does go well and the more miles I put on the engine the quicker it seems to get :) Not really done much apart from completing the 2000 mile european road trip. Hit Polo Treffen in Ho
The book is lying cos my haynes said that the bend must face upwards, whereas on my mk2 it doesnt fit that way cos of the arb and all the geometry looks wrong
Swap it round
Swap it round
Cool... Will do it tomorrow!! :thumbsup:
Hello!
Good job on this Mk2! But I've a question, wich size are your wheel with the A048?? :disgust:
Hello!
Cheers :) :thumbsup:
The are 14 inch rims with 185/55/14 tyres..
Mark
Well I have finally added a mod that will increase BHP by a promised 10%... I've added some go faster stripes!!! :lol:
Also I picked up this bargain today for £3!!!
I have fitted the sender and I just have to get a pod and run the wiring. Also I'm after a oil temp gauge to go in the pod! :)
Those sprint images are great! I want!
Why did you have to faff about with wiring the rev counter? Mine was pretty much plug and play - something I miss?
something to do with the mk3 wiring loom i guess :biggrin:
Yeah its something to do with using the Mk3 engine loom. or something.... :)
Cheers... I'm quite liking the pics.. Its nice seeing the car on the move :arrow:
Well I have fitted the grill... I'm not 100% I like it but I think its growing on me...:)
I have also fitted the sender unit for he Oil Pressure gauge.
I'll get it all wired up properly this weekend.
Also I have got my self some reading for next years winter project... :paranoid:
Well I have swapped the the ARB round and i think it feels a little softer at the front which could be good to reduce a bit of the understeer.
I forgot to get pics before I swapped it round but here are some pics
You can see at the front that the bump actually sits flat when its on giving some extra clearance to the manifold.
Here you can see how it clears the end of the gearbox
And here you can just see the marks where it was fouling the gearbox
Mark
Another round of applause dude.
Any figures yet? I.e. 0-60?
-Nick-
Cheers :)
Not yet but it is prob about std GT times at the moment may be a bit quicker as its lighter.
I want to get one of those performance box's so I can get some details :)
Mark
Well I have just been down to a public weigh bridge and I have found out that in its current form the car weighs 760kg (with a full tank of fuel which I have worked out to be 30kg... i think). So 730kg with 75bhp That's 102.7bhp/Tonne :). I am going to try to take down to Aldon this week or next to find out what power it is pushing out before I start messing with the engine.
Edited by max_crox
Well I have just been down to a public weigh bridge and I have found out that in its current form the car weighs they picked a number out the sky which was 760kg
corner weights for the win :thumbsup:
EDIT to boast - 800kg at 96bhp = 120bhp/tonne
Edited by GiorgioGT
good work max glad to see your able to enjoy the fruits of your labour now :)
Cheers :)
Picked this up today :)
I'm not sure if its actually going to save any weight but it should hold me in a lot better :)
I have dealt with a cooling issue today.
I was using the coupe S radiator (which has the breather pipe to the header tank) with the GT fan but I was finding that the fan was not kicking on until well up in the temperature range (just over 3/4) which I wasn't liking.
So today I switched to using the GT rad which, according to ETKA, is 525mm vs the Coupe S's 380mm. I kept the GT fan unit as the socket on the Coupe S one is different but I swapped the fan blades over. The GT one only had 4 blades but the Coupe S one had 6.
These changes make a big difference. It now takes a lot more 'effort' to get the temp over half way on the gauge and when it does the fan kicks in just before 3/4.
I have also fitted a Poloace chip. Initially I didn't feel any difference so I switched back to the std one but after trying it again I feel it has smoothed out the power and increased it a bit high up in the rev range. :thumbsup:
Edited by max_crox
have you got round to fitting that bucket seat? did it come with proper subframes or you gonna hash some up?
Not yet. I have a Mk2 Golf subframe and I did a trial fitting but I don't know if its mk2 fittings or this this subframe but it doesn't fit right. The rear legs are too high. So I'll get them cut down and re-welded so they fit.
Its the cable that is red with a black tracer as shown here.
Run a cable from the coil in the engine compartment through the bulk head and up behind the dash. You will then have to cut the the wire that goes into the plug (give your self a good few inches.) Attach the wire you have fed through to the one you have just cut. Soldering them together then using some heat shrink would be the best solution.
Once you have done that attach the other end of the cable to point 1 on the coil (under the flap). I would recommend you use one of those connectors with the hole in it rather than just wrapping it around the terminal (but I am sure it would work fine :) )
I traced the Gt loom today on my Mk2 and the rev counter signal wire is connected, via the 20 way plug in the fuse box, to the other end of the red/black wire you cut. I assume the Mk2 counter cannot use this signal. But surely rather than running another wire you can just use the red/black wire where it comes out of the 20 way connector in the engine bay. You could then just soldier to it and run a cable the 2" to the coil. Not forgetting to insulate the other half you cut off. I may be missing something though?
Edited by deajam
I'm sure there are a few ways that it could be done and to be honest I never investigated any other ways of doing it. It was just easier for me to run a wire from the top of the coil to the dash than trace the wire through the loom.
What you say though I think should work but my brain isn't working too well at the moment :)
I know what you mean, it's just quicker to get on with it sometimes. Oh well as you say it seems like it should work. I'll wire it up in a bit and post the result.
did you do any runs at the pod on sunday?
i saw the car there but not on the strip
Unfortunately I didn't get chance to do any runs. Next time maybe! :)
Got a quote for my new exhaust system that I should be getting at the start of May, But I just need to source a 4 branch first.
Also I have tidied the front speakers in the car as they were beginning to annoy me..
They aren't great but do the job!
Also I picked up this head the weekend. I'll be looking to get this ported and polished
