Sold
This is the second time uploading the car due to a woman reversing in to my in a car park and me being a little unsure as to whether or not it would end up going through insurance.
The car now has 60,500 miles on the clock and is pretty much completely standard with the exception of 16v interior and a Sony headunit with aux.
It's a 1.4 8v with aircon and electric windows, having just replaced the regulators they now work as they should.
Mot'd till December 2013
Taxed till January 2014
Cambelt was done at 49k
Oil change + Oil/air filter change around 4k ago if that.
In the time I've had it, it's had two faults one being a misfire which was cured with a new dizzy cap, leads, plugs and lamba sensor.
I have flushed the brake fluid through with fresh fluid.
The coolant was also changed around jan time
Its just had a new back box but it needs adjusting or possibly sealing due to it blowing slightly.
Central locking kit has been wired in so it uses the newer golf style key.
The exterior and interior have both been protected by autosmart products.
Bad points
Fair amount of rust
Number of scuffs though out the car
But mainly the area which was bumped it has a dent and a scuff which is pictured, quite hard to notice once the car is a bit dirty.
Since changing the suspension back to standard it is in dire need of the tracking setting up.
Overall I feel the car will make a perfect run around for somebody, cheap cheap often returns 40mpg+.
The worst of the rust
Any questions please ask, price is £450 Ono and I'm based in Manchester
Edited by jack92
  • Views 195
