6N2 Polo GTI clock surround
Polo GTI clock. Different because its gloss black instead of the normal grey plastic. Looks a lot nicer than the standard one. Took it out of the wifes and now it looks a bit poverty.
I can either send you the entire clock surround or just the piano black bit its up to you. You can just pull the bit off your own and clip this in which is the easiest way. But if your surround is damaged then you can use this. I'm fine either way, just makes a difference to postage costs.
5ABCE0F4-401B-43B9-8E11-14F0553FFA04-312
£15 + shipping.
Edited by heartagram
  • Views 171
