60/40 H&R Cup kit
I have fitted the above kit to my MK2
The rear has settled at the height I expected, however the front is sat a little high.
When I fitted the kit I replaced the front top mounts. The top mounts that came off of the car were the originals, separate bearing and rubber mount. The new mounts that I have fitted are the revised versions with the bearing built into the mount. I'm thinking these may have been slightly taller than the originals and have caused my problem.
The kit has been fitted for sometime so has had chance to settle.
Has anyone else come across this?
  • Views 848
