erics 85' comet blue coupe
Yeah lol. These recaros are so uncomfy ha
  • Replies 225
  • Views 25.2k
Rebuilt and rejetted the carbs. Fuckinghell its quick now! Haha.
Idles like shit though for some reason. Was idling so smooth till i took the carbs off yesterday. Didnt even do anything to um!!
theres 2 vids on my instagram if anyones interested.. erixtar1992 :)
slight air leak maybe? also seen the vids on IG and sounds like it goes well man!
I'm pretty glad you actually have an engine conversion that's not a 1.3 8v which actually works lol!
Don't jinx it!
the xclusive valver is still going strong lol dont worry. all my dodgy noises are from my alternator haha
future long term plans:
  1. carpeted false floor with a couple hidden places for storage
  2. half rollcage
  3. 14 inch wheels with sensible offset for running wide tyres
  4. fit my rear polybushes
  5. couple spots of welding
  6. fix fuel tank issue
  7. exterior respray
  8. mappable ignition (aldon system or preferably megajolt)
  9. new bonnet
  10. straight through centre exhaust section
  11. refurbed gt rear beam
  12. g40 front brakes
  13. flock spare mk2 dash
  14. rear strut brace
  15. recover my recaros or fit some proper buckets
  16. cams for the engine
  17. rebuild my spare head and have it flowed
  18. new clutch
yeah I'm sorta dreaming, but i know i can do most of it if I'm patient and keep track of money. itl get done, eventually :)
All do-able man! some good plans in the pipeline, should be a well sorted car if all goes to plan! :)
think sort fuel tank issue should be top of that list eric :lol:
not a future plan either, a now plan maybe?
plans are decent tho, cant believe your not running G brakes already tho, deathtrap much? God, whos MK2 was it i drove not long ago? and the standard brakes were horrifying, oh i remember, it was yours at poloshow :lol: :lol:
The list isnt in order, just the jobs i wanna do by end of summer next year
Sup with the fuel tank dude?
Plans sound sick, cams would be awesome.
1231450_10151825439510977_1279127238_n.j
Sweet man :)
Doesn't look bad being raised up a bit either
if you ignore the reverse rake
thought you raised it up!
still sits nice pal! gotta be worth it
i have. the front is now only lowered 80mm and the back is about 70. back sits a tad lower though annoyingly.
kill a kitten or two upfront? or but a new spring set up, only £100 ish new!
80 is the lowest you can get. plus £100 is alot when an angle grinder is £15.
although I'm enjoying the height at the mo. can even get over speedbumps.
on the lookout for bigger wheels anyway so it wont look as silly.
I think you should leave it like that! Looks epic.
need 14's
I'm on the lookout for some.compomotive mo5's
Me too haha, I'll stick to speedlines then
not much to update, apart from winning the EMP Performance raffle at players.
this meant that i got a custom exhaust made for free, to my specification!
opted for a straight through 2 inch, to a shallow rear box so that it could be tucked up as out of view as possible.
also got a new rear hanger that bolts through the floor and is solid,
and a 2.5'' outward rolled upswept tip with mandrel bends tig welded together.. looks cracking!
also got my manifold shortened whilst i was there :D
oh, and i swapped my camcover for a different one too.
578644_10201682394118320_1734874542_n.jp
providing all goes to plan, (fingers crossed)
my current short term plans -
  • golf front coilovers and fit my rear 6n coilovers
  • have subframe modified for more clearance so i can lower the car more
  • new wheels with better offsets to run wider tyres, got my eye on a set currently
  • fit my rear beam polybushes
longer term plans -
  • rollcage
  • kamei X1 sideskirts
  • G40 VWII brakes
  • potentially new seats
  • drop the fuel tank out, and have the sill welded up as its now self destructed!
  • respray
Edited by erixtar1992
You were parked next to me at Players Show.
Looks Good.
