MK2F 86c Breadvan 96k
VW Polo MK2F 86c Breadvan / estate 1.3 NZ mpi H reg 96k
This is my 1990 H reg polo estate / breadvan. It's done 96000 miles, the engine is in top condition, no noises or problems. the car has some service history from purchase upto around 2011. I have done alot of work on the car myself and it is in perfect running order
The Good:
• V5 2 sets of keys
• Tax till end of sep MOT till oct
• 1.3 NZ multi point injetion engine, 8mm HT leads, new distributor cap, vacuum hoses. recently serviced
• lowered 60/40 on brand new TA shock / springs, will go over speed bumps at 20mph without a problem and is comfortable in general
• New top mounts / bumpstops
• New track control arms
• 6N chrome top caps
• New front wheel bearings / CV boots
• Braided brake hoses
• Poly Arb blocks
• Polo GT 5 speed gearbox
• Polo GT front seats, small tares on the driver seat but nothing to major
• Black carpet
• Polo GT clocks / rev counter
• Polo GT steering wheel
• Teardrop alloys with good tyres. alloys curbed at the edge but the faces are ok
• Colour coded door hanlde armour plates
• Clear indicators / side repeaters
• De-badged grill
• Mk2 golf golfball gear knob
The Bad:
• Body work needs attention. there are small car park dents along the sides and scratches. lots of light scratches on the sides and roof that will come out with a t-cut, I've pictured some of the more noticable marks. there may be one or two more about the body but on the whole its al completly fixable.
• Has an original casset player which is awesome but I can't tune it to the radio, I have the code but i believe it is a loose wire leading to the areal
• Had a small knock on the front driver side, bent front pannel below the light. has been pulled out and looks ok. I have a replacement section that comes with the car if you want to replace it.
• Rear door cards are a differnt shade to the front. I have some front cards that can be fabric dyed to match the rear door cards.
• Front and rear seats don't match
• Small chip in windscreen on passenger top corner
• one of the side repaters has a broken clip and sits off angle
• Battery tray has been repared, undersealed and plastic lined. Doesn't bother me but isn't a oem look. underseal can be removed with white spirit.
On the whole the car is in good shape. Its 23 years old and low millage with that in mind. very strong engine with tuning potential.
Think I have covered everything but there might be something missed
please contact me with your questions or before buying the car.
£1200
Cash on collection, or if you insist on paypal the fees are covered by you
  • Views 301
