Chris's Mk2 Polo Build Thread
Had a chat with and oldish bloke on the phone he said 45 pound to check it refurb take of the vac advance of and change the spark curve to a fast road curve, I thought I'd snap his hand of at that price how much did he charge you out of interest? If you don't mind me asking?
  • Replies 34
  • Views 11.1k
Was quoted 115 originally but got charged 105 maybe I heard wrong, either way I'm very happy with what they have done. Dubownerbilco payed 45 for his to be done... And they removed his vacuum advance mushroom differently to mine. No idea why. I had full refurb, advance curve, removal of vacuum mushroom and new distributor cap and rotor arm.
  • 1 year later...
I cant believe its been a year and a half since i last posted on here. A LOT has happen since the last time...
The Afh/Avy 1600 Hybrid has come to a stop still sitting on the engine stand all pretty. All extras are still boxed up collecting dust.
I havnt been able to bring myself to sell it as i spent a lot of time building it, and was hoping to use it but i will explain a bit later on.
I become a Dad about the same time 12/11/13 that the progress stopped and once i found my self back in the garage doing work on my car.
I brought this back in Feb 14, it had not been M.O.T 'd Since 09 and had been sitting for around 4+ Years in Grass.
35764ec6-565c-4f83-8b95-9b07eff0467d_zps
I Brought It with the intention of putting the 1600 hybrid in my red coupe and using this one as track/weekend toy. The main reason i brought the car was i liked the original G40 intercooler position/splitter and the wheels it also had a couple more bits that are fairly hard to source on there own.
FBDFB513-945E-4E7F-AFDB-CF28A00E1072_zps
So i Shall Leave it there for the moment.
bastard! i want one of those splitters!
Haha cheers Eric! More progress to come stay tuned ;)
So i got the car home and completely cleaned the exterior to get rid of all the green and see what i was dealing with.
The next job was to completely strip the interior as all the carpets were wet. Either the sunroof was leaking, door seals were perished, or the battery tray was corroded.
I then checked the engine to make sure it was sound, i drained the oil and fuel, topped up with some new stuff. Cleaned the plugs and it fired up on the button with a new battery and there was no rattles and no smoke. I did a Compression Test that Was all Fine.
Soo the Plan was to tidy it up around the edges...
*Check For The Leak
*Check For Rust
*Spray Door Shuts
*Service
*Drive
Well it didn't go that smoothly to say the least... I was not happy with the build quality or the fact that it had been sitting for 4+ Years and i knew nothing about this car. So the car was completely striped down until all i was left with was a bare shell on axle stands and a list of Parts.
The first job was to check the battery tray... in a word it was dead.
Next on the list was to check the floor pans, seals, mounts, chassis legs, arches.
First thing i noticed was the spare wheel position was beyond even attempting to repair so that was cut out, track car didn't need that anyway, in a word scrap.
I spent the next couple of weekends with a friend, attacking the under body seal with a heat gun and wire wheels. i was shocked with what i found.
The Outter seals and inner seals were in need of replacing, both rear arches were in need of some serious repairs.
The Rear panel and inside the boot was full of filler. From an educated guess i would say it had been hit up the ass and covered up.
And The Floor Was just full of small holes and a couple of larger ones.
The pictures give it more credit than it deserves otherwise i wouldn't of done what happens next.
The car was far beyond my repair, and i would of had to spend far to much time and effort to get it to an ok state and i was not prepaired to do that.
So this happened... i do apologize for the graphic content, some viewers may find disturbing.
CA82B90F-ADA0-4304-86A8-F5DB41546F0F_zps
A9105C12-398E-423D-9A54-5D4AA0020B52_zps
D3C2A8DF-B5B6-4CF5-A41E-1AF0C8C6330E_zps
3FBD06B1-A809-434A-9315-50BFA59A225E_zps
116875A2-541F-42A7-8E29-DCD362B3D7EB_zps
67A13E34-9D4C-4FAF-810C-13C90AB165B7_zps
R.I.P G762 FCP
Edited by Chris1991E
I Probably should have given up at this point and just sold up...
But I Wanted BOOST :D and i had all the parts that are needed for a half decent G40 setup.
Soo i was now left with this list of parts from the scrap shell:
Coupe S shell - Scrap
Complete Glass -
G40 Interior -
Black vinyl door cards -
Ta Technix Coilovers -
G40 Rear Axle -
G40 Brakes -
Drums & Shoes -
G40 Head & Block -
G40 Ta Technix Manifold -
G40 Ta Technix Twin Box Exhaust -
65mm Steel Toothed Pulleys -
GT Inlet -
51mm TB -
G60 Injectors -
JabbaSport Induction Kit -
Gt Rocker Cover-
Gt Steering Damper -
Coupe S Clocks and Surround -
Stage 4 JabbaSport Charger -
8P Gearbox - Swapped For An ATV Box
Mk2 Polo Front Mount Intercooler -
Mk2 G40 Front Splitter -
Compomotive Mo5 Wheels -
Luk Uprated Clutch -
Lightened Flywheel -
Fuel Tank + Fuel Pump Setup -
Intercooler + Charger Pipe Work -
But i now only have one shell, So I had to make a Choice.
Afh/Avy 1.6 Hybrid.
Or
Py 1.3 G40.
So i went ahead and brought another Py G40 Engine Setup:
Rebuilt Forged 1272 Block -
Ported G40 Head -
Ported G40 Inlet -
51mm TB -
Lightened Flywheel + Uprated Clutch -
JabbaSport Stage4 Charger -
PSD Manifold -
PSD Twin Box Exhaust -
65mm V-Bands -
315cc Injectors -
E.c.u + Harness -
Schrick 252/276 Cam -
Vernier Pulley -
Travel 3 Hours To Birmingham after work while still bidding on Ebay for it.
So Now I Had Two PY G40 Engines :D
So i was now left with two PY G40 Engines and one AFH/AVY Hybrid.
So The Choice was Simple Build a Fast Road/Track Car.
So My Poor little 1.0L Polo got stripped to a bare shell and planning begun and i started collecting parts.
First Things First i sent one of my JabbaSport Stage 4 Chargers To Roettele Racing for a G45 Full Rebuild + G45 Map and 250 kPa Map Sensor.
Sent My Injectors to Clive at AutoTronixDevelopments for cleaning and testing.
079D3A6B-D26A-47AA-8AB4-1FE2907F5734_zps
B8AE01D6-D1E0-4943-97DE-C9B74C5A70CA_zps
Sent my Cylinder Head off for rebuild + 3 Angle Valve Seats.
The next thing i did was weld in a rear strut brace that StinkyPete Kindly Agreed to make for me!
F405C189-E777-4305-9E25-19C21FD6AAC3_zps
6B68FD3C-8DF3-4673-A3CC-1640EB4ED2B0_zps
The next thing to do was try and fit the 22.2mm master cylinder... but the bottle fouls on the body. so once again StinkyPete kindly Agreed to make me an alloy spacer.
725EBD59-F05D-471E-B515-31418585E472_zps
65290F5E-3CB3-4941-BB90-C902651C2789_zps
The next thing to do was mock up and fit the intercooler + Pipe work route.
So i got hole saw happy and this happened, Made holes on the out side and the inside to allow air flow.
FBD33E69-BE5B-46BF-8950-A2398924E94E_zps
9A3B474C-CB3A-49F4-BBBD-F4D851DE1D52_zps
BD769196-2A8F-48D3-8129-A009E5C3EBD5_zps
Thats It For Tonight Enjoy!
Awesome.
Spacer looks good, wish I had done it this way now but i instead cut the push rod down and used a custom fluid reservoir set up.
Awesome.
Cheers Buddy!
I just ordered a mk2 golf master cylinder and bottle and made it work the best way I could think of!
It wasn't fun removing the studs from the pedal box.
