mk2/f and 6n engine parts
Couple of bits I need gone from the garage
6n parts all off the same 6n engine (1.4 APQ code, 70k iirc) (1.3 aav 100k)
Collection from Stafford ST17, postage can be arranged
6n parts
Throttle body, £20
Inlet manifold, £10
Injectors and rail, £20
Camshaft with pulley, pretty sure the code is 030-E, will have to double check though, £10
Starter loom, £10
Mk2/mk2f parts
1.3 aav cylinder head, good condition no bent valves etc, £15
1.3 8v dizzy, good working order £8
1.3 aav camshaft £8
1043 HZ bottom end, 51k good working order, can still see origional honing marks, £20
1.3 AAV bottom end, spares or repairs as threads for head bolts are fucked, otherwise a good lump £15
4 speed gearbox with mount, 51k no crunches and recent fluid change, £10
Pancake filter with elbow to suit most mk2/mk2f engines, £3
8v cam cover £3
Can get pictures if needed
Edited by staffordmk2
  • Views 108
