VW Remote Control original VW flipkeys with AH-blank keys
Some more OEM++ stuff for sale:
Version2:
Complete VW flipkey radioremotecontrol
The package contents:
• two complete flipkeys, original VW and NEW (434,42MHz) including "AH"-key blanks
• one receiverunit original VW, already encoded with both flipkeys
• one wireloom selfmade but professional manufactured, according to the original wiring diagram and on original connector for receiverunit. The other seven ends of the wireloom are open and have to be connected to the car electric by crimp/solder or any other similar method
• two spare badges for the IMMO-transponder swap, the original badges have to become destroyed to open the flippart of the keys
The receiverunit has got the following functions:
• opening contrallocking
• closing centrallocking
• feedback via indicators for opening and closing via remote (1x = opened / 2x = closed)
• diagnosticbus, one wire gets connected to the cars diagnosticbus, so you can delete lost keys or encode new keys (up to four), delete faultcodes, read measuring value blocks for trouble shooting
• automatic relock function: the receiver gets connected to the cars wire "doorswitch" where usually the inside light is connected to. So the receiverunit knows when a frontdoor is open.
Does the centrallocking becomes opened, but no door becomes opened within 30 seconds, the receiverunits logic assumes it was a wrong use and closes the centrallocking after that 30 seconds.
Just that the car is not unlocked for days as a consequence of a wrong use.
• works with every 12V positive controlled System cos the receiver gives out positive signals on the open- and close outputs
• space for Immo-Transponder (if required)
• all OEM VW Parts, so spare parts supply secured
140 £, delivered to the Poloshow
  • Views 204
