Central locking wiring connector
OK, you'll have to excuse my noobiness here. I was in the process of fixing a broken electric window regulator on a 9N and got held up at the point I needed to disconnect all wiring from the inner metal door panel and remove it so I could fix the regulator more easily. For the life of me I couldn't figure out how to remove the central locking wiring connector. The Haynes manual was no good and I found little info on the interweb.
Anyway, after prodding around a lot I finally figured it out and through I'd post the pics in case anyone else hits this problem. It turned out to be really simple, it's just that it's a really awkward and cramped place to work.
So, here's the offending article before I started:
Here's where to stick yer small fltablade screwdriver:
Here's what the central locking unit looks like with the connector off:
And here's the wiring connector, free to thread out from the inner panel:
Hope that's of some use to somebody in the same position as me.
Andy.
  • Views 951
