leaking sunroof
since its started raining I've noticed my sunroof leaks ALOT when it rains! its like asif its not shut properly but it is, when i close it its fine then after a while there is a gap, I'm not sure if its due to the seal around the glass just needs replacing or not plus it leaks out of the sunroof surround inside the car also.
Any help would be very much appreciated!
It is a 6n polo aswell if that helps.
  • Views 712
