Fixed - poor performance
A few weeks into my Polo ownership. Even though the gearbox is an automatic, and the throttle is managed by an ECU, I found
the performance very sluggish and unresponsive, especially when the car was warmed up.
So I suspected the air duct flap might not be doing its job.
On the air intake, this flap initially takes warm air off the exhaust pipe exterior, and once the engine has got to operating temp,
its mechanism then closes off the hot air, and only regular air is directed in.
Anyway, I took off the airbox and blew a hairdryer on the mechanism, and no movement to close the flap.
The timble-sized actuator was not pushing out its mini piston. And it looks hard to replace as it is encased by the airbox plastic.
As a temporary measure, I fixed the flap to cold air side by using two self-tap screws through the airbox plastic.
Car is running really well now, pulling much stronger. (Lets see how it behaves as winter draws in)
  • Views 528
