Someone help plz coilovers.
I bought some jom coilovers and fitted them yesterday but the drivers rear strut keeps popping through why ? Pics included I've checked it against the other side and it's the same setup could it be seized or what ?
post-107170-0-93028900-1378798353_thumb.
  • Replies 25
  • Views 1.6k
Anyone surely some knows what's going on ?
perhaps the rubber top mount that sits up underneath has perished leading it to pull through? worth a look mate :)
I thought this bud so I took it off and the rubber mount is pretty loose and alot of slack compared to the tight fit the other side is
Anyone else before I order some bushes Is it something else ?
Have u assembled it coorcetly with the spacers on the coilovers there should be two tube spacers on the coilover above the first nut then the rubber that sit under the turret top then you have a nut the another rubber, and a nut then you have a top cup with a nut again. It should all be tight and sandwiching the turret inbetween the rubber top mounts the but poking through is the top isn't it? Just it's lifted up. Do you have the to cap?
Pic this is the kit I bought its the one on the far left.
It's makes a Bang/knock noise too.
Another pic
post-107170-0-80894100-1378881679_thumb.
post-107170-0-64095800-1378882102_thumb.
post-107170-0-79657700-1378882128_thumb.
Have you got the domed shaped washer on the underside
Ye it's on the underside of the top bush is this wrong ?
Should something be securing that bush down
post-107170-0-64723000-1378891010_thumb.
I'm confused here in the picture it looks as only one rubber is fitted there should be two with a nut and washer holding the lower one on then again on the top one. Then the cap with another nut. Compare it to the other side and see what's missing
Should it be like this
post-107170-0-91033400-1378891416_thumb.
Should it be like this ?
post-107170-0-51722200-1378894017_thumb.
Right took both struts off both are set up the same accept the tube spacer was thinner so I put a thicker one on now they both feel firm with the rubber mount. So I set both up identical and it still pops through on the drivers side ? :(
Or is it something with the actual strut ? I can push down on it and it will go down but then just pops back through again I just don't understand there both set up the same :/
U have the cup shape washer the wrong way around on the bottom rubber there should then be another of those washer on the tip rubber with nut then a big cup with another nut if it keeps popping through buy a new mount
Isn't it just meant to be like this tho with no washer or cup shaped washer on. The bottom rubber mount
post-107170-0-95238100-1378919172_thumb.
Surely a washer goes under the bottom bush or something to stop the rod from poking through
You have the rubbers the wrong way around the one in the first picture goes on the coilover with a cup washer and nut holding it then the one you have in a pic above goes inside the car again with cup washer and nut then the plate and nut
So the big rubber goes inside the car ?
Right I have a small rubber and big rubber. Two dome shaped washers and tube spacer can someone tell me how it's assembled ?
2 spacers then big rubber then cup washer and nut then fitt to car then small rubber cu washer and nut the big cup thing and a nut
There's only that spacer.
post-107170-0-16924200-1378973166_thumb.
Okay so u have the coilover off then you have the silver top cap on top of the spring then u have a spacer then you have a nut this nut holds the space and top cap tight now you want to put the big rubber on slide right down till it sits on the silver top cap now ger a cup washer and nut and do them up. So now we can fit to the car. Get the small rubber on there and fit a cup washer and nut. Then finally get the saucer lookin thing on top with another nut. If the other side is fine just copy that side
Found the problem took the silver cap off and it was missing the washer underneath finally sorted cheers for you help :)
