cheap CHEAP work hack
Here's a suzuki swift GLS 1.3 petrol i'm selling for my brother who is now living in London and has left this car here, it's not been used for nearly three months and does have a few bad points which are;
various rust spots
a dent in the door/rear quarter from where he reversed into a bollard
the drivers window doesn't operate (i think the motor just needs replacing)
bonnet release is a bit dodgy
the worst point is that it has an intermittent starting problem (which could be the dizzy cap, but haven't had time to look,but if it's used regularly this shouldn't be a problem as i'm sure the main cause of this is it's little use) but once it's running it's spot on.
Tax runs out 30/09/2013 so will need taxing or trailering away. MOT runs out in March 2014
good points are;
very economical
cheap to tax
runs sweet and pulls strong
power steering and gearbox are both great
very reliable and low mileage
cheap running costs and insurance
to summarise this car is not a looker and is cosmetically a little worse off but it's a mechanically sound (apart from the dodgy start, but should be an easy fix with someone with time/patience) it'll make an ideal first car or something to learn in or even more ideal for someone to use as a daily hack to drive to work and back in as it's a comfy little car with plenty of life left in it for not a lot of cash. Any questions, drop me a line and i'll try my best to answer them.
1374877_10153296464370481_597788174_n_zp
1238167_10153296464570481_1806263334_n_z
1378162_10153296464085481_413638404_n_zp
1380080_10153296464250481_30362010_n_zps
1379985_10153296463870481_36807224_n_zps
]734400_10153296464480481_1510416438_n_zp
i'm located in Redcar, near middlesbrough i'm after £250
  • Views 258
