Best way to sort rust
My drivers door sill has had a bit of bubbling paint for a while but paint has now came away and rust is showing, any ideas on how to get rid of it. Many thanks
  • Replies 11
  • Views 1.1k
  • mattieboi6n
    mattieboi6n
    The best way to get rid of it is to cut it all out and weld in new metal. However if you bring it down till must of it is gone and good metal is showing then u can paint some rust stopper over it and
  • Above post is pretty much spot on Grind down with a flap disc till most of the pitting is gone, not too much or you'll thin the metal though
  • peterabbott33
    peterabbott33
    If your car has done 170,000 miles like mine then a bit of rust is forgivable lol
The best way to get rid of it is to cut it all out and weld in new metal. However if you bring it down till must of it is gone and good metal is showing then u can paint some rust stopper over it and the fill prime and paint. But rust will spread so best to take it out while it's still small
This may sound silly but is the product simply called rust stopper?
Is only a small bit that's hardly noticeable as the door hides it but don't want it getting worse
There's loads of different ones they come in a gel and a paint on. Hammerite do one which I believe is could rust stopper. But have a shop around I know stinky pete uses a gel but can't remember what it's called have a look through his last through pages on his build he mentions it
Thanks for the replies guys, hopefuly going to get everything I need to sort it over the weekend
Not there yet, maybe a few more years lol
Try Vactan or POR15 - best on the market for rust conversion...Cheers, Chris
Pete uses Jenolite.
I have used POR 15 which is a wash, an etch, a treatment, and then a paint. It's very good as the paint since nice and thick. I've used it on battery trays and things.
Pete uses Jenolite.
Dont get por15 on your hand though :P
