Breaking ARC 6N2 POLO GTI Engine 1.6 16v
Breaking ARC 6N2 POLO GTI Engine.
Recently pulled this out of my polo.
And Replaced with another ARC engine which didnt burn so much oil.
I never got to the bottom of the problem as I haven't had the head off and checked it. It would of been as economical to stick a new motor in so thats what I did.
Anyway. What you can see in the pics is whats available. I will begin to break it down in to the individual components. If there is anythign you need please email me at x58nso@gmail.com
Pricing as a guide. All prices are not including postage. I am in Aberdeen so base postage estimates from here.
Inlet Manifold £15.00
Exhaust Manifold £15.00
Rocker Cover £20.00
Head £10.00 (will probably need skimmed)
Cam Shafts £10 each
Block with internals £30.00 (could be a bad piston ring)
Timing pulleys £5.00
Misc nuts and bolts £2.00
I have got a sump but someones put a nail through it. tiny hole. if you can fix it and want it then £5.00
Coolant Pipes £10.00
Clearly more detail will be provided on enqirey. If you need a specific component or several then get in touch and we can sort something out.
PIC 1
PIC 2
PIC 3
PIC 4
PIC 5
PIC 6
PIC 7
Tom
  • Views 554
