MTX Thunder 6000 12" sub in MTX box
Up for sale is my MTX thunder 12" sub.
Only selling as i don't have space for this in the boot with the pram now.
Its in mint condition and sounds spot on.
It does have some screw holes in the rear of it where the amp with mounted on the back but the are very small.
Here is some spec:
Its the T612-44 Thunder 6000
-The Thunder 6000 series is called the ‘little brother’ of the original Jackhammer sub-woofer (plausibly the king of sub-woofers).
On this note, we would be expecting something impressive considering the heritage the T612 has.
The T612 is all about bass. It’s minimum wattage is at 400W, which is already quite a bit of oomph. Considering that it has a max peak of 1200W, you are definitely in for some bass.
- Frequency response: 33Hz to 200Hz
- Power Handling: 400w RMS 1,200w max
- Glass fibre cone
- Die cast Aluminium chassis
- Large Butyl rubber surround
- Dense front foam gasket fitted
- Tinsel leads woven into spider
- Dual 4 Ohm voice coils
- Dual sets of spring loaded ‘StreetWires’ speaker terminals
- Voice Coil Diameter: 60mm, 220 degrees hi temp type
- Mounting depth 199mm
- Triple stacked magnet
- Efficiency: 89dB 1w/1M
- Xmax 16mm
- Fms: 33.1Hz
- Qes: 0.75
- Qms: 5.1
- Qts: 0.65
- Vas: 38.6 Litres
- Comes In A High output MTX Slotported Enclosure
- Vented enclosure
- Unique slot port design
- Designed to deliver loud and accurate bass
Here are some pics:
I am looking for £150 ono
Any views welcome, also can be shown working :)
  • Views 381
