Car has died, help ASAP pleases!
Just had someone out and it's defo the alternator! Finally getting somewhere! Thanks for all your help guys it's really appreciated :-) X
  • Replies 50
  • Views 3.3k
  • Use a multimeter set to 20V If the battery registers less than 12V you need a battery. EWhen the battery is on and the car is running you should see around 14V if the alternator is working. If it i
  • id say battery or alternator imo
  • Your alternator has died u can check by putting a volt metre across the battery terminals while it is running should read 14v.
