Removing Steering wheel from old spec (1991) Mk2f polo coupe- Photos added.
Hi, replacing indicator stalk on the car and need to remove the steering wheel.
Problem; Steering wheel removal on my car model is different from that in the Haynes manual.
Here's the stage I'm at and what I'm faced with;
* Can tell its going to be relatively simple, but I don't want to break anything by forcing anything.
This is the steering wheel after removing the plastic face from it.
Question; How do I remove this part of the steering wheel?
-The only place I can see is to press a screw drive into the back of the steering wheel, but nothing is budging. I don't want to break anything.
- Has anyone done this type of steering wheel before?
Can someone tell me where to go from here?
Thanks a lot!.
  • Replies 7
  • Views 1.1k
  • poke a flat screwdriver in that notch and prise out the center piece ...comes out pretty easy just mind you dont stab the wheel or yourself with the screwdriver once youve loosened the nut leave it
You need to pry the plastic centre bit with the contacts out using a screwdriver
Do it at the bottom
Do it at the bottom
Hi mate can you elaborate on that completely?
* Tried to pry the plastic out by pressing into the bottom but nothing is coming loose (feels like something is going to break..).
Here's the notch on the top (I don't know if that has any relevance??).
Do I just press some screw drivers into the slots?
- It's really not budging at all so I want to know exactly what I'm doing as I don't want to break anything here?.
Thanks a lot!.
once youve loosened the nut leave it slightly on and yank the wheel ...that way you dont belt yourself in the face when it comes off
So to make sure I get this right; just one screwdriver into that top notch, and prise it out?
-Tried that, but felt like it was going to snap....
Is there anything I'm missing?.
Thanks a lot!.
yes do that ...dont be scared off it , I've had a few off and nothing broken yet
Thanks mate- got the entire thing off (No probs at all!. Just didn't want to break anything as I hadnt done it before.).
- Turns out my socket wrench doesn't have a piece big enough to fit the bolt.
* Do you know what size is needed to get the main bolt off to remove the steering wheel and get at the mechanisms behind it?
Thanks!.
24mm
