mk2 polo coupe
Do you have a pair of door handle armor plates? if so what condition are they in? and How much?
  • Replies 50
  • Views 3.8k
How much for the engine? I assume this will go in a breadvan as its still a mk2? Tried pming you but it wouldnt work
Standard exhaust or aftermarket ?
Hockenheims.... you got the centre caps too?
Please PM me if you do as I'm not on here alot.
Have you still got both front top mounts? If so how much posted?
Do you have the number plate lights and screws with seal?
post-15736-0-40375600-1389625159_thumb.j
What carb do you have? also what make exhaust?
Do you still have the engine
Do you have the metal dividers between the front windows and the triangle windows? Also, do you still have the door cards?
Would you be willing to cut out the fuel filler surround and post it? Assuming its rot free?
Josh
Any pics of the door cards and seats thanks
Any chance you have all the door seals still intact?
Have you got the in line fuel pump ?
Do you have the boot door with all the bits attached? wipers etc
hi do you have the rear bumper brackets ? if so how much ? cheers
After the arch kit mate, PM coming your way
after the lowering springs and shocks if you have them i'll drop you a pm.
Still have the windscreen?
Does it have a single choke weber carb ? If so would you be willing to sell it separate from engine ?
You got an aerial or any mirrors?
What's the state of the front bumper?
Hello. Have you got the dash speaker grilles?
Do you have the driveshafts?
do you have the door cards?
i have just got another polo and need some doorcards
