[GROUP BUY] Mk3 full length rain tray?
the vents are there to allow air from the grill to flow over the engine and out, flling them in may lead to a higher engine temp
no its not , its just for the heater fan
thats why theres a metal bulkhead sealed with a rubber seal to seal off the engine
  • Replies 84
  • Views 4k
  • oh i was thinking make a wooden buck /mold or whatever its called then fibre glass ..or carbon fibre heres some a pro has made for a rado
  • Yes I will be speaking to him about this in the dimensions and see what he can do with my measurements for making the prototype
  • Hopefully be speaking to him very soon and meeting him, and see what he can do, hi previous work looks good making fiberglass wings ect cheers
I'm going to figure out how to DIY one myself seems as the plastic one that is std has split in 3 places. Might use some MDF as a rough template first then using a sheet of vynil plastic/perspex ill heat the fusebox side and taper it using a pipe or something. summer project
Yep. That's what I meant.
Mines a flat sheet I'm having trouble with the wiper mech hitting it at the moment but soon to be fixed :)
Edited by Buxton
Wiper mechs been hitting my allsmiles carbon jobbie and has taken a chunk out :(
Was thinking of buying some CF cloth and giving it a go, adding a ridge into the passenger end of the mould to create a drain channel but just wouldnt have the autoclave to cure it properly
can still do the carbon just for looks similar to normal fibre glassing
id planned to fit in a piece of mdf, shape up up how i want then use that to lay down some fibre glass on the underneath so that mdf edge provides the lip you need to fit the tray
  • 5 weeks later...
Any more news on these ? would be very interested to hide all the crap in my scuttle !
Well everyone wanted one with a lip so I've sorted myself out with a flat sheet that hides my alarm an lots of wires ect and I've left it for
Someone else to pick up and find a supplier if their interested
so do we get photos ?
Agreed pictures would help. And dimensions etc.
