Removing rear badge on 6n
How do i remove the rear badge on my 6n? I can only find out to do it on 6n2 and not sure if its the same. I painted the inside of my front badge earlier and it came out very well, wanna do the same to the rear.
Thanks in advance!
  • Replies 6
  • Views 1.9k
  • The rear badge is in two sections, the plastic VW logo is attached to a rubber backing which is glued to the car. Get a hair dryer on the badge to warm up the glue, get some floss/cotton/fishing line
Get a hair dryer on the badge to warm up the glue, get some floss/cotton/fishing line down the back of the rubber and use it to 'cut' the glue and pull the badge away from the car as a whole.
The VW part is kind of 'riveted' to the rubber part with little plastic struts, you can chop the back of these off the back part of the rubber to separate the two (you'll see what i mean when you get it off)
Paint it, wrap it, do whatever it is you're wanting to do with it and then re attach.
You'll want some decent double sided tape to re attach it to the car once you're done.
:smile:
Thanks! Two detailed guides in one day ay! I'm gonna post some pics of my front badge soon and will post some of the rear when its done. :)
Oh how I wish I'd read this post earlier!
I errr, snapped the two rivets LOL
oh well, superglue it is!
Me too it was the easiest way but a bit of glue will be fine, after all how long is it going to be before you need to take them apart again. I just put them back together and put a bit of double sided over the back of them, then just stick it back to my car. I haven't tested the strength of the tape yet though. It seems strong I haven't even used any glue.
post-913013-0-98127100-1389903333_thumb.
So this is how you do it hahaha for years I've just pulled it off, snapping the rivets and then put back on with super glue. LMAO!!!
Haha it was a moment of genius... it is still on the car so the tape has stuck. I keep forgetting to take photos.
