The Punisher
2013 Polo 6R GTI
BBM Channel Pin C002931FB
http://www.pgti.co.za/pgtiownersclub/viewtopic.php?f=3&t=300
IMG_00001978_hdr_edit_edit_zps79addff9.j
Current Mods:
1. Straight pipe exhaust (Stock Diameter - Middle resonator & rear muffler deleted) with Powerflow twin exhaust tips.
2. Clear lamination on headlights.
3. Yellow Lamin-X on fog lights.
4. Original B-Sting aerial.
5. Interior lighting all LED's.
6. Turbo heat shield spray painted with matt black engine enamel.
7. Air intake duct, the flexible connecting pipe and the turbo pressure pipe covered with exhaust wrap.
8. Disconnected the Sound actuator.
The Sound Actuator
Current preferred Go Juice: Shell V-Power Nitro+ 95
*Current VCDS Mod LIST*
1. Disabled rear wiper convenience wipe.
2. Disabled headlight washers.
3. Activated coming home feature with the cornering lights.
4. Hill hold set back to Normal, Hill hold on early setting not suitable for heavy traffic conditions.
5. No audible sound when unlocking, only indicators.
6. Indicators comfort signals set to 2 flashes.
7. Enabled teardrop wipe for windscreen wipers.
8. Disabled interior lights coming on when removing key from ignition.
9. Enabled emergency brake light flashing feature. I don't know if it works. The emergency hazards do come on during very hard braking.
10. The volume of fuel required to refuel displayed in MFD.
11. Speedo correction closer to true speed. Top speed of 235km/h indicated on MFD.
12. Steering Aid set back to Stock feel, GTI(Sporty Vehicle) feels too heavy.
13. Needle Sweep
14. XDS set at Strong setting.
15. Heated mirrors also on when rear window heating is activated.
Wheel Power :
Autotrix Dyno: 126kw & 251nm - Stock
Autotrix Dyno: 131kw & 251nm - Straight Pipe Exhaust
Autotrix Dyno: 130kw & 264nm - Chipbox
Autotrix Dyno: 137kw & 275nm - Chipbox + Straight Pipe Exhaust
Stealth Dyno: 146kw & 290nm - Chipbox + Straight Pipe Exhaust
Flywheel Power
Experience Dyno: 141,5kw & 275nm - Chipbox + Straight Pipe Exhaust
Sound clip of dyno run:
https://skydrive.live.com/?cid=b1b97a91a5d4f436&id=B1B97A91A5D4F436!157&Bsrc=Share&Bpub=SDX.SkyDrive&authkey=
Wife's
2011 Polo Vivo 1.4 Blueline
Ex:
2011 Volkswagen CC 2.0TDI DSG Bluemotion
2008 Tiguan 1.4TSI Trend&Fun
2008 Polo 1.6 Comfortline
2006 Polo 9N3 GTI
2006 Polo Classic 1.6 Comfortline
Edited by polo6rgti
  • Views 2k
