Changing headlights
Hi,
New to this site
I'm having a problem taking the headlights out the new style polo.. Iv unscrewed the top two screws but the light doesn't seem to be coming out?
There isn't enought space for me to put the bulbs in hence me trying to take the whole light case out, could someone explain how I can take the lights out?
Thanks Marco . 2010 polo tdi
  • Views 1k
  • According to ElsaWin if you have a 9N3 then the only additional work required to replace the bulbs is to remove the battery for better access. If you have the 6R Switch off ignition and all electr
I was wrong below is correct answer
If you have the 6R
Switch off ignition and all electrical consumers and remove ignition key. – Protect bumper cover from damage with commercially available adhesive tape. – Release multi-pin connector - and disconnect. – Remove securing bolts -2- and push headlight forwards out of lower fastenings. – Remove headlight forwards from body aperture.
No Mention of removing the bumper cover for replacing the bulbs !!
Edited by nige8021
