Chris's Derby Gls Barn Find Project
so not updated for a while been busy moving house and with work
I got this patch in a few weeks ago
And got a few hours in today while I'm trying to find a front end i decided to make a start cleaning out the inside removing glue and poking holes as i go.
Started to cut out the rot on the drivers rear window it actually runs along the window frame about 6" so some fabrication needed. Hopefully get this done tomorrow and where the fuel tank filler runs there is a patch need on the inside.
Also noticed today that because the steel pipe inside the rear quarter for the tank breather
had rotted out the whole back end of the drivers sill is shot and its been patched before so another one added to the list.
The plan for the time being is to weld as i find to save it all building up and I'm going to get the inside steel work clear and cleaned back and remove the seam sealer as the inner sill will need some work on the drivers side.
so cut the small section out
groung back and treated for now I'm going to blast and re treat then paint before making the repair.20141227_131347_zpsmcqrecds.jpg
and cut this out and welded up
And started clearing all the glue and dirt off and started removing the seam sealer on the seat panel.
so blasted the rear window support and treated before i left tonight.
also got the car turned around and i started on the drivers rear inner sill area,
its pretty bad it has been repaired before bu just welgin a plate over the top of the rust.
i need to drop the rear beam before i do any cutting on the rear end as the rots right up to the mounting point on the drivers side so its going to be fun fabricating the new parts.
so rebuilt the corner of the window frame and removed the strip further down along with splitting the seam to clean out the start of rust.
i just need to get the dremel in the corner to smooth out the welds.
also started on the floor sill area while the rust killer is on the window frame.
  • Replies 59
  • Views 13.7k
Wow, some serious work here chief. keep it up
Loving the work going into this!
Keep it up!
window frame done just a few welds that need grinding in the corners.
Top work - very impressed
Yeah very nice Chris.
What are you doing for shotblasting? I'm thinking of making something for a few small parts on my build but would love to know what others have done.
I've got a small sandblaster I use but I've also got a cabinet I need to sort out for small bits, and i use kiln dried sand from bnq. I think you can get sand blasting guns you can top load like a paint gun for small areas it may work.
Edited by smed
Nice one. I've just bought a Sealey SB993 shotblaster after seeing your success. Will let you know how I get on with it. It was very cheap at £35, plus £20 for a 25kg bag of media.
this is looking excellent, looking forward to the finished product
This looks amazing looking forward to seing it finished. I'm also mid way through mine but mines a mk2 still finding holes at the min so no welding for me yet :(
Keep the updates coming bud your doing some fine work.
If you need any info on sealers, primers and other such chemicals you might want to check out my thread I'm doing a similar build just no where near as rotten (thank god).
http://www.clubpolo.co.uk/forum/index.php?showtopic=256117
Edited by dirtydubs
So not a proper update i had knee surgery at the start of the month and I'm still crippled,
but on the plus side managed to get myself a front panel from Germany, its not genune VW but a HS part and its actually really good quality. Defiantly not a lot left to get for the metal work, I'm just trying to hunt down some one breaking a 2f with a solid rear beam mounting area that they will cut out for me.
Edited by smed
Looking forward to seeing what this turns out like. Keep up the good work [emoji2]
  • 5 months later...
so no updates for a while i had knee surgery in Feb ACL reconstruction and cartilage repair, this meant i wasnt going to be able to do any work for a while. and I've been busy healing and basically trying to get fit.
i basically admittedthat the welding work needed doing by a pro so the car is with Lee Mcglachie at Auto shack.
hes just started the work and its safe to say he's doing a top job.
11900033_853591278063423_177373748124523
11880548_853591288063422_799653220739441
11924572_853591511396733_101927811305143
you're the right owner for the car, few people would put this effort into such an old car. will look mint when its done
indeed mate its all fun need to spend my money on something lol its got a long way to go yet.
  • 6 months later...
so no updates for a while i had knee surgery in Feb 2015 ACL reconstruction and cartilage repair, this meant i wasnt going to be able to do any work for a while. and I've been busy healing and basically trying to get fit.
Edited by smed
not updated for a while Lee had been working his magic saving this.
still got a few jobs left to do but looking forward to getting the shell home.
11960060_857748514314366_850520522952461
12189603_886667748089109_621867384271946
12208347_886667704755780_667973996965222
12191775_886667654755785_917911784923478
12189085_886667728089111_654490838022977
12631317_927948047294412_917350690431617
12642437_927947967294420_564635333779337[/url]
12644973_927947997294417_657129473415813
12642870_927947960627754_452671736563050
12661854_927948067294410_335998886994146
12647145_927948033961080_423296961179373
more updates hopefully wont be too long till i get the shell back.
12742255_940682102687673_173275810766884
12728959_940681919354358_544949630055254
12729361_940681962687687_786644153759946
12742502_940681952687688_636986616818485
12742344_940681922687691_755120707719631
12744084_940682109354339_176334475254267
12742348_941364835952733_840001945857493
12745608_941364822619401_672186748734601
12742843_941364759286074_479605438423932
943977_941364779286072_65309607643086838
11204949_941364752619408_662408271408741
So welding all done. picking up the first week of April
1620684_954585874630629_2883667804831850
12512499_954585924630624_769566812924335
947094_954585911297292_45561040302797309
10152598_954585881297295_881764598345121
10410498_954585937963956_414870870484354
1919239_954585964630620_5710258536274798
wow. Proper rotisserie/spit restoration. This will be better than brand new when finished. :smile:
Nimal x
  • 1 year later...
Been some time but the cars now gone to paint.
Derby going to paint.
shells at the painters hes had some delay getting it to the blaster for the underside.
should be soon hopefully
shell is blasted and in epoxy, was only blasted on floors inside and out. this exposed a few holes that need some further welding.
also the rain tray is going back in.
37019379603_975f3d0620_k.jpg20171013_155903 by Chris Smedley, on Flickr
37690186311_dab5e8b092_k.jpg20171013_160330 by Chris Smedley, on Flickr
37019373343_746cebd2c5_k.jpg20171013_160407 by Chris Smedley, on Flickr
37690181811_a9f7dadfcd_k.jpg20171013_160412 by Chris Smedley, on Flickr
37690181401_20ea1e5101_k.jpg20171013_160336 by Chris Smedley, on Flickr
Edited by smed
  • 3 months later...
starting to move again
https://farm5.staticflickr.com/4750/39373630174_aee1a2e440_z.jpg[/img
also started zinc plating bolts and brackets
Just read this from the the start and that’s a hell off a lot of work you’ve put in! Top effort mate, it’s come a long way!
nuts!
what engine you got planned?
anything supercharged
