Door wont lock.
Hello, my drivers side lock has started to not lock when using the key, it unlocks perfectly fine and sometimes locks. and can be locked by pushing the pin down although the pin seems to catch at times so i'm thinking that's where my problem is rather than the lock itself. I'll be taking the doorcard off to take a look and just wondered if anyones had a similar issue in the past and what the cause was.
Thanks.
  • Views 610
