Breaking 16v Polo
Yeah would need whole engine bay loom, can you send me some photos of the plug that goes to the ecu, joshg60@hotmail.co.uk
  • Replies 45
  • Views 2.3k
  • Once again....... in the UK some polo mk4 1.4Liters 16V with the damned AFH engine have drums on the rear axle, some have discs. Believe me. There are no rules like in other countries. Here we have
  • Sorry already been sold.
Hi does this have headlight adjustment ? If so how much for the headlight wiring loom (19pin connector to 7pin headlight plugs) ?
Could I buy just the front bumper ?
Hi, yes I still have that part of the loom, and it is the one with the adjustment and 7 pin plugs would be £10 with the postage. You can buy the front bumper however it is quite badly damaged and would need repairing if you know some who can plastic weld it should be reasonably easy. Do you want the grills as they are really the only part of any value. Also where are you as it is quite large although not heavy so postage would be difficult if you can collect its not a problem.
Hi, could you give me a price on the cylinder head?
Hi Bob, the drum complete with axle would be £20, not sure of postage cost but its quite heavy. I will have to get it off and weigh it to get an accurate cost. ....Cheers Gary
Hey mate... i just need the drivers side stub axle now please... managed to find a drum... i dont need the abs sensor or anything with it... just the stub axle itself... howmuch posted please and i can paypal you the money asap... could you send me a pic of it too please
Hi, if you just need the axle it would be £15 including the postage. I will take it apart tomorrow and send you a photo probably best if you text me your email. Cheers Gary
How much for rear lights posted?
Hi speedbump i do not really want to split the engine as it is running o.k and I probably would be left with the bottom end. But what would you offer for the head if i were to split it?
Hi Jay, rear lights would £20 plus £5 for postage.
Cheers Gary
Think 90 is highest I'd go as bought one that I've stripped and found out it's scrap so need another asap.
Hi Speedbump, what do you want for £90 would it just be the head, with cams and valves etc. do you need the camcover or belt covers, manifolds etc. ? I imagine you would need it posted as I see you are in York. as that would be extra. Cheers Gary
I have now stripped the car completely so have all parts available.
Here are some examples
Doors - £20
Window regulators - £10 each
Throttle body - £30
Injectors that were professionally cleaned and not fitted - £20
Interior carpets full set 4 pieces - £20
Central locking pump £20
4 suspension struts complete with springs - £40 will lower 8v about 20mm (one rear shock is leaking).
Front brakes complete disc and caliper - £40 virtually new disc's and pads.
Front hubs £40 the pair.
Drive shafts - £10 each.
Gearbox - £100 just changed oil with £30 worth of synthetic (would have to be collected).
Gear changer assembly cable type. - £10.
Drivers and passanger airbag £20
Plus loads of other trim and brackets etc. Text me and i will give you a price.
I am away this weekend but will be around from monday and will deal with everything then.
Cheers Gary
Can't tell if this has a sunroof?
Hi, yes it does have a sun roof and it is available £20 plus the postage. I do not have the drains so you would have to rig something up for that but I have the headliner if you need that. Postage would be expensive so you could be collected or I see you are in London so could deliver depending where about for petrol costs. Cheers Gary
hi how much would the central locking pump be posted please my old part number is 1h0 962 257f if you could text me on 07854828567 thanks
Hi, how much for the full engine loom (inc fusebox, ecu, immob etc)
Have you got the original cat and are the gear linkages and cables okay?? Also what condition are the solitudes??
Hi Jonny, sorry cat has been sold and the Solitudes are not for sale, However I do have the gear linkage and cables etc which are in good condition. £20 including postage as i doubt you want to collect it. .....Gary
Do you still have the front bumper?
Hi, no sorry bumpers both sold......Gary
