open air sunroof woes
I've got a 2001 open air model, and today I tried opening the sunroof with the first bit of dry weather...typically it now won't work after never having a problem before. The motor is whirring round when you press the switch in both directions but it doesn't open at all. I took out the panel with the interior light to look at the motor, I read on some old forum posts that you should just undo the two screws and unplug the wiring and it should come out?! Certainly wouldn't come out on mine and I didn't want to attack It like a bull in a china shop. Has anyone else had problems with these and can suggest anything?!
  • Views 604
