Silver 1985 Porsche 944 LUX 2.5 8v
Beautiful 944 to drive, responsive, light clutch and gear box, very little whine through the torque tube for a 944 of this age (common in pretty much all of them). Taken for some long drives and used happily as a run around. Only done 977 miles during the year I've had it and never missed a beat, starts first time every time.
Bought a year ago for breaking but it was far too good to go this way. I have done tons of work to the mechanical side of the vehicle and restored the interior though unfortunately due to job and circumstance changes I can't afford the time or money to finish her off, will be very sad to see her go but would be perfect for someone with the skills to finish her off!
Flew through the last MOT which is valid until 30th May and Taxed until the end of June.
No rust where it matters, good solid sills. Inside of sills and wheel arches etc. treated with ACF50 corrosion protectant. Bit of surface rust to be seen to.
Good bits
  • Brand new tires fitted 15/04/13
  • Full service 01/02/14, oil & filter change, spark plugs, fuel filter, air filter
  • Gear box oil change and treatment 02/06/13
  • Always fueled with 98 RON Shell V-Power Nitro+ and Redex injector cleaner
  • Brand new, fully refurbished front and rear seats installed 24/01/14
  • Replacement part worn rear silencer 01/11/13
  • Front & Rear alloy UK pressed plates
  • New Cam belt, Balance belt, rollers, tensioners & water pump fitted with new thermostat 22/05/13
  • Coolant flushed and replaced 22/05/13
  • Upgrade vacuum piping 27/05/13
  • JBL 45 watt door speakers
  • Sunroof up and down works perfectly, as does lifting it out completely.
  • Engine runs so smoothly and quietly showing good oil presure, 4.5 - 5 under load and 2 - 3 when hot and idling
  • New radiator 01/08/00
  • New clutch and slave cylinder fitted 19/07/00 only done 24,248 miles since then
Bits in need of attention
  • Cracked dash - see picture (unfortunately fairly common in these old cars)
  • Missing windscreen trim - see picture (spare included with sale)
  • Cracked front bumper - see picture (spare included with sale - including front head light washer jets)
  • Dent in rear near side arch - see picture
  • Red wing mirror - see picture (why haven't I sprayed it myself by now?)
  • Electric mirrors don't work due to red replacement not being electric - though you only adjust them once
  • Driver side electric window motor could do with a clean as the window moves slowly
  • Rear window demister wire needs soldering back to wire strips
  • Passenger window works from drivers side not passenger - probably in need of new switch
  • Rear seat belts not fitted due to new seats being fitted and I couldn't bear making holes in them (3 point seat belts included with sale)
NOW SOLD
Thank you very much all those who enquired
Edited by Eddy_6n
  • Views 376
