Can't open front door from inside and outside, help!
Hi,
Wondering if anyone can help a newcomer to the forum on a big problem I just encountered with my 9n polo.
Been having problems with off side front door not opening with the remote key, solution was to manually insert key but I bit the bullet and decided to buy a brand new module and fit myself.
This afternoon I swapped over the module, re assembled with a brand new one closed door and bingo it worked!
Opened door to remove my tools, closed it again and now for some reason I am unable to open the door at all both from inside and outside....
I've searched high and low on the internet for a solution as to how I'm going to open the door with suggestions of removing door card with the door shut to pulling the handle open slightly and poking a coat hanger in to release the mechanism?
I've tried lowering the window and shining a torch down the gap where I can see the linkage moving nicely when I pull the handle from the outside, I've also tried without success in poking a coat hanger down there with a bend in it to try and pull the cable but nothing, it's as if the thing has deadlocked?
The inner door handle is floppy and quiet possibly come away from the cable...
Removal of the door trim with the door closed is proving to be non starter, I am quiet frankly beaten....
Has anyone else been in this situation or have any other possible solutions out there I can try before I end up waving the white flag and passing it onto Vw to maybe sort out?
Thanks in advance
Darren
  • Views 675
