polo 86c mk2f mk3 coupe 1.3 spi
Looks about right, do you have the carb to sit on top of it? How much?
  • Replies 96
  • Views 2.9k
yes i have the carb i can take out from the dead engine but I am not sure on how the carb performs or will perform as engines dead and i have no way of testing it, i will need to find out the postage for the whole lot
Alright, give me a price with carb and without, i will need to check whether my 1.0 unit will fit the 1.3 manifold.
Hi there. Have you still got the brake servo? Does it work and how much you want for it posted? Thanks
is it the one thats on the driver side under the bonnet the round black thing?
In need of the throttle body that sits under the injector, if DeanH doesn't take it of course :)
Is there any rust on the drivers side front wing? Do you know if it's the same as a mk2f saloon?
oh and a rear spring
If all ok how much?
wing has some imperfections although i cant see any rust on arch or at the bottom part of the wing, the suspension spring or the whole suspension leg?
Only need a spring but whatever's easier for you stripping. Have you got a side on shot of the wing?
If all ok how much?
i will check the condition of springs tomorrow and the pictures for the wing too
Boss I forgot to ask you today is the oil condenser breather pipe ok? it comes off the rocker cover down to a T piece the one half goes to bottom of engine and other part goes to under side of pancake filter ?
post-4280-0-58962600-1398456569_thumb.jp
Edited by 1vw2many
Do you have the in tank lift pump available? If you do drop me a pm with price etc as I'm in need of one!.
i will have a look today and get back to you
yes got one, £25 posted, cheers
Got it buddy, can put that in with door handles and key if you dont mind waiting?
pmd
i have got a spare complete throttle body although if deanh doesnt take it you can have that
If all ok how much?
PMD
Il take the in tank fuel pump of you, are these the same across all variants? I.e polo gt, g40?
Paypal ok?
Paypal ok?
hmm. this particular pump came off a 1.3 genesis model but someone on the forum with more knowledge should be able to tell if theres any difference between gt g40 ones but as far as my knowledge goes g40 ones would be f
different.. someone can correct me?
As long as its got a lift pump within the sender unit it should be fine i think, or are the fuel pumps different?
i can post up a picture of what i have so that you can see if thats what you need but to be honest i am not too sure about GT/G40 pumps, did you want it for a gt/g40?
Yes I can wait boss thanks ..
cool
I'm doing a project, I'm converting my 1.3 Carb to fuel injection (GT injwction) and i need a fuel lift pump, A picture will help if you dont mind.
Gearbox okay?
