the wifes 6n2 tdi
as the title...
I thought I would start a thread for the wifes Polo
these pics were taken by P/O but nothings changed bar a scratch on the drivers door which happened about 12 hours after ownership :x
apart from fixing door locks and having an issue with the ABS module all is well.
  • Replies 17
  • Views 3.4k
  • Best thing I've ever owned, fantastic on fuel, good to drive, £30 tax a year... No complaints
  • There is two common faults with the ABS pump unit, first is the fusable link on top of the battery, the often fracture and this causes a voltage drop and this puts on the fail light, you need to remov
Same colour/engine/doors as mine, good choice :thumbsup:
cheers bud.. how do you find yours? so far bar fixing the wee niggles were happy with it.
I've just spent £40 on the right gearbox oil for it as the clutch was done before I bought it and now it doesnt like to select 3rd when coming down the box.
update... changed the gearbox oil today :-(
the fluid that came out it looked right and was clean..
so now I'm starting to wonder if I've bought myself a tin of problems...
so I've now discovered when coming from 4th or 5th if I release the clutch blip the throttle and then dip the clutch it goes in sweet..
so after some searching I've discovered its a common problem and its a sign the box is on its way out. =@
so I'm now looking for a gearbox but also thinking is it time to get oily and rebuild a box....
I've also wondered is it possible to fit a different box? say one from a 1.9tdi fabia or golf?
I've found plenty of threads but bar folk buying recon boxes I've not seen any answers :x
anyone wanting to buy a polo?
well I've bit the bullet... I'm just having a coffee break the gearbox is booked in for a rebuild..
Well I started stripping the box out around 12.30 today and by half 3 the box was sitting on a bench at the gearbox specialist in falkirk. Not bad for an afternoons work
I've pulled the abs module out as well as going to have a look and see if I can get a replacement while the gearbox is away getting rebuilt
There is two common faults with the ABS pump unit, first is the fusable link on top of the battery, the often fracture and this causes a voltage drop and this puts on the fail light, you need to remove it and check for any damage, the other is in this link http://www.clubpolo.co.uk/forum/index.php?showtopic=312683
I'm getting a front near side abs sensor fault code and also when I try to scan with vcds its telling me there's no signal from the abs module. Would any of the faults above cause this? I have checked the fuses on top of the battery but will remove them to double check them.
Cheers James
Edited by jbh110tdi
That's confusing! if your not getting a response from the ABS unit, yet it reports the front nearside sensor??? but that sounds more like the actual sensor or the wiring to it, the resistance of the sensor should be 1~1.3 K ohms
post-36925-0-05227400-1400257848_thumb.j
yea the vcds report is
Address 01: Engine Labels: 045-906-019-AMF.clb
Part No: 045 906 019 AB
Component: 1,4l R3 EDC 0000SG 1210
Coding: 00003
Shop #: WSC 00788
VCID: 55A167D6AFA15BB6975-4B50
**** VIN NUMBER DELETED ****
1 Fault Found:
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 6X0-907-379.lbl
Part No: 6X0 907 379 B
Component: ABS 30 IE CAN V004
Coding: 05603
Shop #: WSC 00788
VCID: 4385A98E5135D506C91-4B36
2 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
35-00 - -
16-10 - Signal Outside Specifications - Intermittent
Ok that's the ABS not talking tothe engine ECU
post-36925-0-97215400-1400263139_thumb.j
Checking data bus Function The control units capable of data bus are connected together via two data bus wires twisted together (CAN_High and CAN_Low) and exchange information (messages). Information not available in the data bus will be recognised as a fault by the engine control unit as well as other CAN data bus control units. Further information: → No.186 Test prerequisite l A fault has been recognised by the CAN data bus self-diagnosis. Special tools and workshop equipment required t Adapter cable, 121-pin -V.A.G 1598/31- t Hand multimeter -V.A.G 1526C- or multimeter -V.A.G 1715- t Auxiliary measuring set -V.A.G 1594C- t Current flow diagram Test procedure – Switch off ignition. – Release connectors on diesel direct injection system control unit -J248- and unplug connectors. – Connect adapter cable, 121-pin -V.A.G 1598/31- to diesel direct injection system control unit -J248- The control unit wiring harness is not connected by this action. – Check terminal resistor in diesel direct injection system control unit -J248-: – For this, perform resistance measurement between sockets 6 + 7 of adapter cable, 121-pin -V.A.G 1598/31-: specification: 60…72 Ω If the resistance measurement is outside the specified range: – Renew diesel direct injection system control unit -J248- → Chapter. If the resistance value is within the specified range: – Eliminate the fault in wiring and in other data bus components according to current flow diagrams → Current flow diagrams, Electrical fault finding and Fitting locations.
This might be down to your VCDS connection, Is it a canbus compatable lead?
yes its a can compatable lead it happily reads my brothers 54 plate passat and reads my dads 08 golf
I've also got a vag/can scan hand held tool that will read can bus and it wont read the polo either.
My thoughts at the moment is to get a second hand controller with the same part number and try that and see if vcds or my scan tool will read it
its also been suggested to replace the abs sensor and then reset it and see if this cures it.
http://wiki.ross-tech.com/wiki/index.php/18057/P1649/005705
"18057/P1649/005705 - Powertrain Data Bus: Missing Message from ABS Controller Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
Possible Causes
  • Fault Code(s) stored in Brake Electronics (J104)
  • Communication Error with Brake Electronics (J104)
Possible Solutions
  • Check Brake Electronics (J104) for Fault Codes
  • Check Communication with Brake Electronics (J104)
    • See Measuring Value Blocks (MVB)"
I'd start with checking the resistance from the ABS unit and see if the sensor is within the resistance range, if not replace/repair the sensor/wiring, then I'd check those resistance between pins 6 & 7 on the engine ECU 60~72 Ohms and do a continuity check from the Engine ECU to the ABS, ECU pin 7 to ABS pin 11 & pin 6 to pin 10
well the wee polo has been back on the road for 2 days and all is going well.
I forgot to take any pictures of the rebuild as was just grabbing time on it when I could between dealing with 2 sick kids
