Polo mk2f/mk3 coupe BREAKING. Everything is available! PHOTOS ADDED!
Hey man
Do you have a driver's side door mirror and the internal adjuster? Mine is glued solid so is purely ornamental!
Would need to be posted to Ireland though
Drivers mirror is no good sorry
  • Replies 62
  • Views 3.2k
Do you have the front bumper and the clips for the rear speakers.
Edited by jono1303
Front bumper is still available £30 posted, do you have a picture of the clips you need?
No I don't have a pic since I don't have the clips but there what hold the rear speakers in place. They are are like plastic push fittings that go on the plastic dowels under the rear speaker grills.
I don't have these sorry
Adjustable driver's mirror and door handle needed, here.
Please PM me as i can't keep checking the forum atm.
Do you have the gearbox fill plug? On top of the box,
Fuel tank lift pump and sender unit posted?
Cheers,
Matt
Hi do you still have parts available I'm after the boot if it's in ok condition. If so how much would you be looking at for part and delivery to stoke on Trent. Or how much just to collect.
Cheers,
Matt
Sender unit is sold
Boot is in ok condition, some rust spots and it needs a respray, cant post sorry. £15 collected
PM'd buddy 👍
Is the drivers side door seal available? How much posted? Cheers
Still available. Dunno what its like £8 posted if its any good
Do you happen to still have the handbrake lever?
Do you have the rubber bit that sits between the wing and the aerial? In good condition? If so how much?
Any luck with the gearbox and both wings
are the rear lights still for sale?
I need the glovebox and the airbox (does it have a filter in?) I also need a lower rear engine mount if you have it? How much for everything posted? Thanks
Rear lights sold sorry
All these sold sorry
is the dizzy a vac advance dizzy with the ignition loom if so how much would you want for it?
Unfortunately this isnt old enough to have the vac advance dizzy as if it was id be using it on my afh build
Hi doesn't look it should be any chance the clocks have a rev counter? If so how much posted?
I need a spline adapter off the steering wheel?
No rev counter sorry.
I do have one. If I find it ill let you know
just need the O/S brake line from the master cylinder to the flexi
