Track day car?
Hi
I have a 96 model 1.4CL spare only done 67k from new I'm think of turning into a track day car for some low budget fun - not a clue where to start on cage - engine spec tuning (cheap remember) shafts - brakes - suspension etc you name it any info would be greatly received - would like to put it back on the road and if want use in Road rallies and hill climbs if all this is possible please throw the info my way.
Kind Regards
Darren
  • Replies 24
  • Views 1.5k
  • Its a car which is here and now, Ill do something to the clutch and brakes and Suspension for sure - Ill be looking for a cage as well - ill try and take out as much weight out of the car at the sa
Cages are not cheap to start with looking at 600 quid Minuim. As for engine upgrades not much you are gunna gain other than fitting the gti lump if u wanna stay injection and probaly the cheapest bang for buck. Or build the 1.6 16v afh hybrid on carbs to get 150 bhp but gunna be more pricey. Gti brakes all round some light alloys (not cheap) some decent rubber toyo or yoko advans (not cheap 100 quid per tyre). Strip out everything u don't need this is probaly gunna be the cheapest option for u. Suspension is really budget depending cheap doesn't really get u anything good. Yeah 200 quid coilovers will get u better handling purely cause it's lower and harder but u won't be as good as a set with dampening and rebound adjustment but they aren't cheap. Basically a cheap fun track toy isn't cheap.
Unless you buy my cheap fun track toy that is for sale:
http://www.clubpolo.co.uk/forum/index.php?showtopic=333149
A standard 1.4CL 6N would need quite a lot spent on it really to make it a fun track car, and yours is a low mileage one so would seem a bit of a waste to use that as a track car.
Even if you ignore a power upgrade and don't fit a cage, you still need wheels & tyres, suspension, performance brake pads, bucket seat and harness. That (plus stripping it out) would give you a usable but slow track car, but you would do well to get all that stuff for less than the £900 I'm asking for my car that is already track ready and is definitely a lot of fun (ask Mark Croxford if you don't believe me).
You could then sell your 6N for around the same amount as you buy mine and you would have a track car for almost nothing!
Sell it and grab and old MX5 or MR2 for some cheap track fun!
Saxo vtr are dirt cheap and quick now. But if you want to keep it strip the interior and a pod filter and race it round until it dies/you crash.
Edited by vdoubleu
It really is the basic if you are on a budget and is only gunna be used on the track take everything of that's not needed one seat I would advice getting a good harness and steering wheel without airbag or remove take dash out all sound deading if you are serious get the car on its side and strip on the under seal seem sealer and all unneed brackets through out the car get a sheet of polycarb and make a template of all windows bar windscreen and seal polycarb window in. And the diffrenece will be huge u could also take a hole dipple tool and go drilling holes every where although I wouldn't advice doing that without a cage.
Also cheap up grade would be to change brakes to but setup discs all round remove abs and get u self a flaring tool and some fitting and make all new brake line and get braided hoses where rubber flexies are will improve braking feel a million times over. And abs unit is pretty heavy (if fitted of course).
Power wise stick engine go down local parts store and order a metre of exhaust tube what every size urs is and remove cat and centre silencer then get some hose and cheap pod filter and fit behind head light somewhere as far away from exhaust manifold with a heat shield around it if u can afford.
A realistic budget would be around 500 quid and for that I would be a cheap bucket seat harness and mounts.
Edited by mattieboi6n
Hi
All this info is great - I have a full set of racing Harness here - got some track days tyres and slicks(car these be used) brakes and suspension is what the 1st job ill look at so it stops and goes round corners!!!!
What about Shafts are these OK?
Whats about CWP maybe lowering the ratio?
Gearbox strong enough?
Just all questions will come up in next few months -
Prop wont get out in it this year looking really next (unless I win Lotto lol)
I have some ideas about taking the central locking out etc putting hatches to keep hatch down keeping it light on there.
The one about discs all round I'm keen on this.
I'm making notes on all the info - its all great.
Hi Dan - I dont have £900 in cash I'm affraid thats why ill be doing it all in stages and picking up bits as I can etc. Its a bit of fun on the side nice n quick so mrs doesnt notice lol...
Keep it coming lads/lasses more info the better.
Cheers
Darren
I'm also building a track car for next season only diffence is I have a jetta to start with.
As for the new questions drive shafts should be fine depending on boot condition as long as they haven't been exposed to water for a long time should be good.
Gear boxes are crap on these and it would probaly be ideal to keep a spare around. I know my jetta is running a small block abd 1.4 lump pushing 122bhp and is on it's 4th box have no idea why it does em. I'm currently running a gt box and it's lasting longer.
If I was tracking it I would certainly look at changing the clucth to the 200mm afh option just to deal with the harsher gear changes better
Removing door locks and speakers and stuff is also a good idea. Just basically get the wieght down as much as u can to utilise the power it has.
Obviously budgets small but I would certainly be looking at fitting a bigger arb. Maybe look into seeing if the gti arb is bigger as this will be cheaper than the likes of eibach. Made a huge diffence to the feel of my car.
id get bored driving a 1.4 cl on a track. you probs will too my advice is to sell it, save a bit then buy something that is actually worth it lol
Edited by erixtar1992
In reality the cheapest overall thing to do is to sell the car and buy a cheap car that is already track ready (MX5 and MR2 as suggested by someone already are good suggestions, or my Polo lol).
Converting a car that is not a very good base for a track car and needs a lot of components upgrading will end up costing you a lot more.
If you really want a 6N track car, and are happy to spend several grand on it but over 2 or 3 years then carry on.
As far as brakes go, converting to rear discs is a waste of time unless you're going to significantly increase the power. On a stripped out Polo almost all the weight is in the front, so the rear brakes hardly do anything. Contrary to popular opinion drum brakes do not generate less brake torque (for a given diameter) than discs, they are just more prone to overheating as the friction face is not exposed to the air.
The most important things to upgrade on the brakes for track use are:
1. Get a good set of track pads (I use EBC Yellowstuff on my Polo and my MX5 and they're good from cold and don't fade)
2. Replace the rubber flexi hoses with stainless steel braided ones from HEL or Goodridge
3. Change the brake fluid to some high temp race fluid to avoid fluid overheating
Standard rear brakes and standard discs on the front will be fine for the time being. You can always upgrade them later if you upgrade the power. The main thing is eliminating brake fade and improving brake feel.
As far as tyres go, you can use road legal track tyres at trackdays without a rollcage, but if you're using full slicks you have to have a full cage fitted normally.
^^ u state the main thing is to deal with brake fade, but u also say rear drums are better even though the heat up a lot quicker meaning faster fad on the rear granted the don't do as much work as the front but they still do something. Have a disc with no back plate will ensure that heat can exscape meaning it will take up longer to build up the heat it to cause brake fade. The only reall way to deal with serious brake fade is a bigger disc and venting of cause,
I think you've slightly misunderstood me. I'm not saying drums are better - clearly brakes that have a more stable braking torque at a wide range of temperatures are better. That means you should fit ventilated discs on the rear, as thin solid discs tend to overheat fairly easily too.
However on a low powered, light car that is significantly front heavy (remember most of the weight you take out of a Polo is in the middle or rear) I don't think you are that likely to suffer from rear brake fade with drums, and even if you did you probably wouldn't notice as the front brakes are doing so much of the work anyway. I've had my Mk2 Coupe S track car for 7 years and done numerous trackdays in it, and as long as I've had good track pads in front and good high temp brake fluid I haven't had any problems with brake fade that caused a noticeable drop in performance when on track.
So what I am saying is that for someone on a tight budget running a sub-100bhp, sub-1000kg track car its not worth spending money on a rear disc conversion as you won't really get much benefit. If you decided to drop a 1.8 20v turbo engine in a 6N running over 200bhp then it would be different and I would definitely recommend upgrading the rear brakes (and the front brakes to larger discs).
When you're on a tight budget you want to spend your money where it will have the most effect on fun or performance (or both ideally).
have you ever been on a track in a polo? if your overheating your rears you probably left the handbrake on :lol:
Well what u rather have rear brakes working at half potential cause the hot or rear brakes working at full potential cause there colder? The fact of the matter is a gti brake set up can be had for 150 and will improve lap times massively over spending 150 else where. The larger vented front disc will help reduce fad on the front which will happen after several laps so it has to be a win win no?
I have never been on a track in polo
Got to say, I'd agree with this. Start with something that's a bit involving to drive in the first place. Make sure it's either got power, or it's not heavy enough to need it.
you have never been on track in a polo, exactly, thats why you are arguing your point :lol:
the drums are pretty up to the job. you aint gonna gain much by having rear disks as they do fuck all work in comparison.
Cool drums it is then. What about the unsprung wieght diffence to be had from fitting disks. Is it not even worth it for that.
your joking though right?
What about reducing unsprung wieght and rotanial mass. Yeah it's a great joke.
you could gain SO MUCH from that tiny bit of weight saving!
be easier to just have a shit before driving :lol:
as if you would even notice? lol
The slightest weight lose in unsprung weight has a big benefit accompany that with lightweight wheels and u will notice a huge difference in the way the car performs. I couldn't say if a shit is the weight difference bit If u want to test I'll supply the brakes u supply the shit. But then u have the problem of the shit being sprung weight and the brakes being unsprung.
Ill be looking for a cage as well - ill try and take out as much weight out of the car at the same time - even look at putting battery in the rear.
Remove as much of the not wanted as I can - drill etc!!!!
I'm rebuilding the engine before it is being complete so look at little mods as I can.
Off away in the morning, for a wk and a bit but will try and get online and keep in the loop on this thread.
Cheers
Darren
Before you start removing all the interior and drilling holes everywhere, have a think about how much of a track day car you want it to be.
What I mean is, if you're planning to trailer it to and from events and never really use it on the road, then go ahead and remove all the trim and the dash and everything.
However if you're planning to drive it to and from track days and want to use it on the road a bit, I recommend keeping a passenger seat and either the glovebox or door pockets as having absolutely nowhere to store anything inside the car will get frustrating. You may also want to consider leaving a bit of carpet in to reduce cabin resonance on those journeys to and from racetracks. If you remove the heater matrix you won't be able to use the car in the winter or when its very wet as you won't be able to demist it.
What I'm saying is that it's not a full race car, and so making some small compromises on comfort for the sake of a little extra weight will keep you happier in the long run. I know because I've been there.
@ erixtar - tried to send a message to you but I failed.
I wanted to ask you a question please. Did you ever manage to get a true bhp figure with your carb setup on the afh?
I noticed on earlier threads you posted you were not running at the full 125bhp so was wondering if you managed to get it all running smoothly.
never had either dyno'd, my red coupe had a 1.4 afh on carbs and was running lean so was a bit underpowered, my blue mk2 has a 1,6 afh and is a stupid amount faster. i was keeping up with some rather expensive track cars on the straights at lydden hill.
