Mocal oil cooler
Just the matrix, so you'd need the pipework and a sandwich plate.
It's a 13-row, 235mm cooler. Used but in pretty much as-new condition.
This is the spec PSD used to give for G40 oil coolers, but it's overkill on mine so I'm downsizing to a 235mm 7-row cooler instead.
These are over £80 new, I'd like £50 for this one. It's a good place to start if you want an oil cooler, as it's the most expensive bit.
I'm in Cardiff, work in St Albans and travel a lot. So I could meet you if you're on the M4 corridor, or near my start or end location.
  • Views 162
