1.6 aee rebuilt engine 90% complete
For sale is my 1.6 aee engine which i have rebuilt as a project
Due to running out of time the engine has not got a timing belt or water pump on it, however this is an easy thing to add and will cost maximum £50
I have spent a lot of money on the engine and replaced:
main bearing shells
big end bearing shells
all bottom end bolts
piston rings
tappets
camshaft (now has a gt cam)
valve stem seals
all gaskets including head gasket, rocker and sump
oil filter
I have also done some porting to the exhaust side of the head
All work was carried out in a clean, dry workshop. all parts were cleaned before re-fitting
The engine will come with a box of ancillaries i have not looked at them since i removed them so i don't know what sort of condition they are in or if there is anything missing. From what i can remember when i received the engine everything was there
Considering the amount of money i have spent on the engine i'm only asking for £150 located in tonbridge, kent
collection is preffered, will accept it to be collected by a courier if it is arranged by yourself
any questions please contact me on 07784374355
  • Views 343
