General tyre size guide mk1-7
Hi I'm planning to run 14x6 et38 teardrops on my mk2f breadvan on 40mm drop. What tyres would people recommend I fit, I would prefer to not have stretch but low profile however I know it's gonna be tight on the rear arch which is why I'm asking. Any help is appreciated,photos even better thanks
  • Replies 37
  • Views 20.5k
  • mbusby993
    mbusby993
    I've got 195/45/15 on my 15" BBS. You won't get any stretch, on mine the tyres stick over the rim. But once lowered, they look good. My car is down about 80mm and if the profile was any higher they wo
  • It is definitely 165:70:14, it says it in the manual and a lot of the Polo/Fabia/Ibiza steels on eBay have 70's, and the tyre fitment guidelines I just looked at online also say 70. Steels are 165
  • According to the 2006 Model Year (effective from 1.6.2005) brochure that I have the following wheels and tyre sizes were standard fitment to the Mk7 that year: E - 5Jx14 steel 165/70/14 S - 6Jx14 Sa
Think my breadvan had 165/50/14 and those were teardrops
Edited by kiran_182
Cheers mate, you don't have any photos do you?
They may have been 165/45/14
Go to the car bible and use the wheel and tyre calculator
15 hours ago, kiran_182 said:
Cheers mate,main thing is  avoiding scrubbing on the back
Youll want to get the same rolling radious as the original steels so your speedo and miles stay correct
Yea,I've been looking into that, the originals were 155 70r13 and the closest I can get to that is 165 60r14 with the Speedo reading 0.9% too quick. Not sure if that's gonna fit with the back arches tho ?
If you're not too low you should get away with a 185/50/14 on the rear with that wheel size.
That tyre size is near identical to the standard rolling radius too.
I'm only on 40mm drop ATM, don't have any photos of how they sit do you?
There’s a website Jord called willtheyfit.com and if you know the specs of your current wheel and and the teardrops it should give you an idea of the change in sidewall and clearance from the hub etc.
Cheers man,most worried about the rear arch
  • 1 year later...
New to polo land and need a hand pretty urgently please guys!
I have a mk2 coupe which is about to go on H&R 60/40 cup kit with baby G60 6Jx14'' ET45 4x100 wheels - I want to make sure the speedometer and mileage are all correct and that the car handles well - what brand/size tyres should I be getting?
Edited by PollyMk2
