drivers window removal
HI drivers window is stuck in the closed position,as electric window wont open,have checked wires in rubber boot (all ok) switch is ok change wiring over and worked on passenger side ok.I need to lower window to under window clamps to remove regulator/motor any ideas if you can do this manually.Many Thanks
  • Views 557
