Vgate Scan 450 fault code reader - brand new
Hi all,
I'm selling this as i now have two, specs below but they are on ebay for around £35. has the 16 pin diagnostic plug, read the and cleared the fault code on my 6n no problem, even 'talked' to my husbands 306 so will work on anything with the OBD2 connector.
selling for £25 posted ono.
The Vgate SuperScan VS450 Scantool is an original equipment manufacturer (OEM) level diagnostic tool for the majority of post 1990 Volkswagen/Audi models, it replaces the obsolete VAG405 which is no longer produced. The EOBD function means the VS450 will also operate on non Volkswagen/Audi vehicles, although not to the same extent.
USER FRIENDLY
Easy to use, with an intuitive interface, the VS450 reads, scans and clears/erases on board diagnostic (OBD) and fault/diagnostic trouble codes (DTC) including those of the engine and transmission, ABS, immobiliser, airbags, A/C/climate control, radio, steering wheel instrumentation, central locking, etc. This stand-alone unit communicates safely and easily with on board computers, displaying results on a large, backlit LCD screen the VS450 has a comprehensive menu of tests and diagnostics.
With Controller Area Network capability (CAN) the VS450 reads, scans and clears/erases using ISO 15765 (CAN), ISO 9141-2 (CARB) and ISO 14230 (KWP-2000) protocols.
COMPREHENSIVE MENU
  • Reset oil service light
  • Reset oil and inspection service interval
  • Turn off MILs of engine, airbag, ABS , A/T and most other systems
  • Retrieve vehicle information
  • Display I/M Readiness Status
  • Display DTC definitions on unit screen
AFTER SALE
One year warranty
Results will vary depending on vehicle make, model and specification
DIMENSIONS
Height : 8 cm
Width : 20 mm
Length : 17 cm
Weight : 550gms
PACKAGE CONTENTS
  • Vgate SuperScan VS450 Scantool
  • OBD2 Cable
  • Carry Case
  • Nylon bag
  • Full user manual
  • Views 342
