6n2 window won't open
my passenger side window won't open, think the motor is at fault which seems a rarity as normally it's reg clips, but when either switches are pressed you can hear the motor click so I'm assuming it has power, I read on the lupo forums this is to do with teeth on the motor not engaging correctly
I've got a new motor from a 5 door, assuming it's a straight swap into my 3 door,
just wondered if anyone has any ideas on how to get the window down far enough to get at the clamps holding the glass?
Edited by Liam6n2
  • Views 555
