Breaking 1990 Mk2 Breadvan
Front struts only dont need dampers or springs just struts how much posted?
Edited by cheddarcheese
  • Replies 39
  • Views 4.2k
price on engine/altinator mounting bracket?
How much for the boot struts? :) also do you still have the glovebox? Thanks very much!
Dou you have distributor?
With Vacuum advance?
Will be stamped 030905205B
Distributor no longer required but...
Do you have boot lock? (part the key goes in and the bit you put your fingers behind)?
Hi, I'm after a number plate light and scuttle panel if available
Lock No longer required.
Do you have inner cam belt cover upper and lower?
I would be interested in a driver's mirror that adjusts inside the car via the knob and works
Hi mate, are the front brake carriers available?
Hey man!
I'd be interested in the headlight/foglamp wiring loom if you still have it mate?
Let me know :-)
is the gearbox still available and how much?
Hello mate I need a set of front shocks and springs have you still got them?
hello mate is the loom still available?
Do you still have the shell? Would you mind if I cut out a couple of sections from the inner wing and front panel?
Sure I need the engine wiring and ignition look as doing a bike carb conversion in a 6n? So if I do have you these parts?
