VW Polo 1.4 8v Blue 1999 Reg *$175 quid *
Year: 1999
Mileage: 98k
MOT: -
Price: 175
Hi all Blue 6n polo 1999 1.4 8V 98k miles this is the 5dr sunroof model with electric windows,
This car was used for 9 months before the MOT came of which it then failed
Apart from the MOT Car needs new passenger front window and theres a Largish dent in the passenger front wing
Failed mot on following
Headlight nearside aim to high
Exhaust leak centre to rear box joint
Offside front suspension arm bush deteriorated causing excessive movement
Brake valve leaking
Nearside Inner seal seat belt anchorage point corroded
Corrosion Same on offside belt anchorage point
Offside front Inner cill vehcile structure has excessive corrosion which affects braking and sterring
exhaust emissions over allowed limits.
someone that has the time,effort and skills ( Welding) to get the car back on the road, will end up with a cheap little car.
Any question let me know.
Based in ashford,kent 175 quid nooffers
Thanks Charlie
post-920644-0-49745700-1432055210_thumb.
post-920644-0-75505900-1432055217_thumb.
Edited by charlieh778
  • Views 349
