Afternoon guys, I found myself in an awkward situation the other day. I had just fitted some shiny new JOM bluelines to my beloved 02 9N but when I set the car down from the axle stands, two problems became apparent:
The car was 60mm Higher than when I started
The drive shaft was rubbing.
I know I need shortened drop links to go lower than about 40mm but the coilovers should have allowed me the initial 30mm drop when they where wound fully up with the helpers still in.(I did try some shorter ford mondeo ones but this didn't help either)
they had to be taken off as no position moved the drive shaft far enough away from the ARB.
Has anyone encountered this before?
I am now looking for alternative cheap coilover options and wondered if any of you could offer any suggestions for kits that would fit?
  • Views 825
