6n heater not blowing hot
Hi, been a long time since I've had to post here!
So my partners 6n S reg has been having problems with the heaters. Confused about what it could be! So:
No hot Air at all, car heats up to 90 and sits there never over heats. Once heated up both hoses going into the bulk head heat up nicely and I have drained the system, flushed it with a hose pipe including through the two matrix pipes (water passes through). Refilled and burped the system. Also when hot the rad fan kicks in about when it should.
The hot / cold switch turns fine and feels like it is moving flaps like it should and when changing from cold to hot there is an obvious decrease in the power of air being pushed out.
So, what do you guys think as I'm lost now!
Thanks!
  • Views 813
